Steering Column Slop on 09 DC
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dalsmthme, Jul 14, 2009.
  1. Jul 14, 2009 at 5:30 PM
    dalsmthme
    dalsmthme [OP] Well-Known Member
    Ithaca, NY
    '09 Double Cab 4X4 SR5
    So I have been chasing several issues with my brand new DC for a couple months now. The dealer has don e everything under the sun to try and get rid off a shimmy I have at 50+mph. One of the things they have been ignoring is a loose feeling I get on dirt roads and stony drives. I think I have traced it back to the steering column. There is 4-5mm of slop in the shaft where is passed through the fire wall. All of the universals look god and there isn't any slop in the rack or any of the slip joints. I guess the real question is if this is normal or not?
  2. Jul 14, 2009 at 7:18 PM
    JeffRock
    JeffRock Well-Known Member
    Capital region, NY
    09 Tacoma accesscab 4x4 SR5 2.7L
    Toyota all weather floor mats. Mag light that clunks around in the jack compartment. Dog hair. Dog drool on the windows.
    I have def. noticed the slop in my 09"
  3. Jul 14, 2009 at 10:20 PM
    Faskev
    Faskev Well-Known Member
    I have noticed the same thing on my 09 when I take it on gravel roads. The steering wheel has an unsolid feel as if there is some play in the steering shaft. This is completely unacceptable as this is supposed to be a truck. I didn't buy a 4x4 to only drive on the interstate.
  4. Jul 14, 2009 at 11:54 PM
    Diablo
    Diablo Well-Known Member
    Calgary Alberta Canada
    09 Double Cab TRD
    I kind have the same thing, i mostly notice a bit of a clunk when i hit bumpy sections of roads, exiting driveways and such mostly at speed. Often sounds like its driverside wheel well area but a few times i have thought it was the steering column.
  5. Jul 15, 2009 at 4:10 AM
    FL4x4Taco
    FL4x4Taco Well-Known Member
    Never paid attention. I will now.
  6. Jul 15, 2009 at 5:04 AM
    dalsmthme
    Ithaca, NY
    Mostly, I am looking for someone who doesn't feel the slop to check there steering column and see if there is play.
  7. Jul 15, 2009 at 5:46 AM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    mine does it...i thought it was something loose in the front end.
  8. Jul 15, 2009 at 6:12 AM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    I swear there was a huge thread on this forum or the toyota ones where someone posted the schematic, and where the issue actually was.
  9. Jul 15, 2009 at 7:08 AM
    Diablo
    09 Double Cab TRD
    Do you just reach under the dash and shake the column to check this ?
  10. Jul 15, 2009 at 7:14 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Did you check tie-rod ends? That'd be my first thing to look at.
  11. Jul 15, 2009 at 7:17 AM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    x2... Theres a good chance its the tie rods
  12. Jul 15, 2009 at 7:19 AM
    dalsmthme
    Ithaca, NY
    It is the intermediate shaft, see the attached schematic.
  13. Jul 15, 2009 at 7:24 AM
    dalsmthme
    Ithaca, NY
    Yeah, I checked the tie rod ends and every other nut bolt and part in the front end. The only thing that seems out of the ordinary is the steering column. I originally found it when I had the drivers side jacked up and was horsing on the wheel and control arms. Pushing in the tire and wheel created a clunking noise. Tracing it back yielded the steering column issue. With the truck on the ground, reaching in and shaking the steering column creates the same issue.
  14. Jul 15, 2009 at 7:27 AM
    Lentsnh
    It has to be the No.2 Steering shaft..... or it might be the sliding yoke
  15. Jul 15, 2009 at 7:47 AM
    brian
    Elizabeth City, NC
    Sounds like my Civic with 250k miles on it... same problem ^_^
  16. Jul 15, 2009 at 8:39 AM
    dalsmthme
    Ithaca, NY
    It is in the intermediate shaft, the assembly that looks like two plates bolted togather.
  17. Jul 15, 2009 at 8:48 AM
    JeffRock
    Capital region, NY
    Ok, Anyone know how to fix it? Should i get the dealer involved?
    It happens when ever i leave pavement.
  18. Jul 15, 2009 at 11:37 AM
    dalsmthme
    Ithaca, NY
    That is what we are trying to get to the bottom of....
  19. Jul 16, 2009 at 5:31 AM
    BSP4x4
    BSP4x4 Guest
    any word on this yet?
  20. Jul 16, 2009 at 5:42 AM
    dalsmthme
    Ithaca, NY
    I havn't had a chance to get doen to the dealer. I checked my Dad's '07 TRD sport and there is absolutly no slop in the intermediate shaft. That truck has 23K on it. There is a guy I work with that has an '09 access cab 4 banger. It has a little play, but not as much as mine. I am still digging around. There are about 3 other guys that have trucks I am going to check...
