Steering Column Slop on 09 DC
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dalsmthme, Jul 14, 2009.
  1. Nov 22, 2009 at 7:10 PM
    #41
    Voos
    Voos Well-Known Member
    Eric
    Albuquerque, NM
    Dbl Cab SB TRD Off Road
    Icon CO's, Total Chaos UCA's All-Pro 3" leaf packs w/ U bolt flip +Timbren, Rear Bilstein 5100's, Dick Cepek DC1's Black, 285/70R17 BFG ATko, ProDryS drop in, Dynomax Super Turbo
    Glad to see I'm not the only one with this problem.. That being said.. I still want it fixed.. Best thing to do is for all of us to get a hold of consumer affairs.. It will take a lot of calls for them to turn their heads.
  2. Nov 22, 2009 at 7:14 PM
    #42
    Voos
    Eric
    Albuquerque, NM
    BUMP! Every one of us should call consumer affairs!!!!!
  3. Nov 22, 2009 at 7:50 PM
    #43
    freesample
    freesample Well-Known Member
    Newfoundland, Canada
    09 Tacoma Double Cab TRD Sport LB
    Visors, Deflector, Husky Liners, too expsensive for good ones :(
    how do we do this?
  4. Nov 23, 2009 at 11:07 AM
    #44
    Voos
    Eric
    Albuquerque, NM
    [​IMG] Toyota Motor Sales USA, Inc.
    Customer Experience Center
    Department WC 11
    19001 S. Western Ave.
    Torrance, CA 90501
    310-468-4000
    Toll free: 1-800-331-4331
    TTY: 1-800-443-4999
    Fax: 310-468-7814
    www.toyota.com
  5. Nov 23, 2009 at 12:08 PM
    #45
    JAG
    JAG Well-Known Member
    I was involved in an accident couple months back in June. Air bags deployed. Had truck fixed.... Now I have this sound. I know it is coming from something in the steering column. It may not be related. But i'm sitting in my truck right now with the dash pulled apart trying to figure something out! lol
  6. Feb 19, 2010 at 9:48 PM
    #46
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    Whenever I go over washboard or small bumps, I can feel this kind of loose vibration and noise under my feet. I installed a lift a few months ago, so I thought it was related. I've gone over and tightened everything on my lift twice, and its all nice and tight.
    Today I did notice that when I grabbed the steering column shaft thats in the engine bay and move it around, its loose and makes that noise that I've been hearing. For the life of me I thought it was related to my lift, but I think I've finally concluded that its the steering column. Have we found a fix for this yet????
    When hitting bumps slow speed, my truck does not sound or feel solid. Help!:confused:
  7. Feb 19, 2010 at 10:01 PM
    #47
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    I too have noticed the slop. Toyota needs to step their game up. All of it.
  8. Feb 20, 2010 at 3:11 AM
    #48
    dalsmthme
    dalsmthme [OP] Well-Known Member
    Ithaca, NY
    '09 Double Cab 4X4 SR5
    I have been looking at these. It is called a tolerance ring. Basically it is a radial spring that when pressed between the gap in the rag joint between the intermediate shaft and coupler should prevent vibration. However, in the event of an accident, the shaft would still slip as designed. Whese are commonly used now in similar applications. The problem is I havnt had time to size out what we would need.
  9. Feb 20, 2010 at 9:37 AM
    #49
    Canadianboy
    James
    Vancouver, BC
    Sounds like it could have potential....
  10. Feb 20, 2010 at 9:47 AM
    #50
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
  11. Mar 5, 2010 at 9:26 AM
    #51
    jamfred774
    jamfred774 Member
    Jamie
    Denver CO
    05 Tacoma SR5 4wd
    4wd Illumination, Sockmonkey Bedside Decals, Extra Bed D Rings, Diff Breather Mod
    It would be nice to figure this one out.
  12. Mar 26, 2010 at 10:02 AM
    #52
    dalsmthme
    Ithaca, NY
    Well, the tolerance ring thing hasn't panned out. I cant find a catolog part that will work and I am not going to pay $5000 for custom tooling. I went back to the drawing board and aquired some o-rings that were about the right size to fit in the gap between the upper and lower shaft rag joint, maybe 1.5mm. I sliced the o-rings and ran them in lengthwise into the gap. This is the only way they stayed. It takes a little while. I used a 90deg bend pick to carefully push the o-rings into the gap. I pushed about 10 into one side. This was enough to bias the shaft to one side and remove any clearance. I tell you what, it's like a completely different truck. Just be careful when pushing them in, if you push out the rubber sleeve that is in there from the factory it is a bitch to get back in.
  13. Mar 26, 2010 at 10:10 AM
    #53
    freesample
    ok you know the next step!
    some pics and how to. heh
    did it take long /expsensive to do?
  14. Mar 26, 2010 at 10:18 AM
    #54
    dalsmthme
    Ithaca, NY
    Well if I get time I will. Don't wait on it though since I am pretty busy lately. Anyone who has watched the videos I posted can see where the joint is. All you have to do next is slip the o-rings in, not excactly rocket science. The o-rings are only a few dollars at an hardware store. The rest is just prezeling yourself under the dach with a pick.
  15. Mar 26, 2010 at 10:22 AM
    #55
    freesample
    under the dash? so its done from inside the truck?
    and what tool is that? a 90 degree bend pick?
  16. Mar 26, 2010 at 1:06 PM
    #56
    Soon
    Soon Well-Known Member
    Do you have the size required? I'm looking into this as well...
    Thanks
  17. Mar 26, 2010 at 2:13 PM
    #57
    dalsmthme
    Ithaca, NY
    Pull The shroud off under the the steering column under the dash. you should see what is shown in the video above. If you can replicate the video, estimate the side of o-ring you will need to take up the clearance. Cut it lengthwise and use any tool suitable of pushing it in the gap with. I used a 90deg pick. Size will be a function of how much clearance your perticular truck has. Mine happen to be about 1.5mm.
    Edit: a 90deg pick is a pointy rod with a 90deg bent at the end....
  18. Mar 26, 2010 at 2:41 PM
    #58
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    So basically you took 10 rubber O-rings. Cut them, so now they are linear but naturally curl because they were originally made that way.
    Then you inserted them into the gap, one by one, each O-ring reducing the clearance until you were happy with it?
    I surmise that the natural O-ring curvature is what helps them stay put inside the gap (rubber sleeve)? The gap/sleeve is circular so it's like putting a circle inside a circle?
    You reference picking a side to insert the O-rings, and I guess that's where I'm a little hung up.
    Thanks for your explanation. Please tell me if I understand correctly.
  19. Mar 26, 2010 at 2:58 PM
    #59
    Canadianboy
    James
    Vancouver, BC
    Oh boy I really want to get this fixed on my truck
  20. Mar 26, 2010 at 4:33 PM
    #60
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    FOX 2 1/2" CO's STOCK UCA's - They used to be Icons! Icons suck!!! TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
