Steering Column Slop on 09 DC
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dalsmthme, Jul 14, 2009.
  1. Mar 26, 2010 at 4:46 PM
    #61
    dalsmthme
    dalsmthme [OP] Well-Known Member
    Ithaca, NY
    '09 Double Cab 4X4 SR5
    You are mostly correct except for the direction. The o-rings should not be a circle inside of a circle when you put them in. You want to unwind the o-ring and have it run along the axis of the shaft. I tried running them around the circumference, but they just would spit out. As far as which side, it doesn't matter. The o-ring will hang out on both ends. Put them in whatever end is easiest for you. Other than that, you have it right.
  2. Mar 26, 2010 at 4:48 PM
    #62
    dalsmthme
    Ithaca, NY
    I know. I will do my best. I have a lot of crap going on right now. If I get a chance I will snap a couple pictures.
  3. Mar 26, 2010 at 4:48 PM
    #63
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Okay. I'm totally clear. Thank you.
  4. Mar 26, 2010 at 4:51 PM
    #64
    freesample
    freesample Well-Known Member
    Newfoundland, Canada
    09 Tacoma Double Cab TRD Sport LB
    Visors, Deflector, Husky Liners, too expsensive for good ones :(
    ok i'm excited. if the weather was good id do this tomorrow. if anyone does this take a few pics or a little video
  5. Mar 28, 2010 at 7:59 PM
    #65
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    dalsmthme, did you have a rattling type noise under your feet, in the engine bay??? I have tightened up my suspension components, and I'm thinking that the rattling noise that I feel is the steering shaft rattling and make a noise in the engine bay.
  6. Mar 29, 2010 at 3:17 AM
    #66
    dalsmthme
    Ithaca, NY
    You can feel the rattle in the steering wheel. You can hear it come from the fire all area. I never really felt it in the floor...
  7. Apr 2, 2010 at 9:30 PM
    #67
    freesample
    any done this and have a picture of where te rubber orings go?
  8. Apr 2, 2010 at 10:42 PM
    #68
    AZM9
    AZM9 Well-Known Member
    Jay
    Chandler, AZ
    2009 Prerunner TRD Sport
    ARE tonneau cover, Redline hood struts, Leaf TSB, and Trans TSB, Satoshi grille.
    Ok, this explains the sloppiness and clunking I had last week when I took mine offroad a couple of weeks ago and the loosness I feel at highway speeds. That makes 3 things they will fix next week at the dealer. The ECM flash for the trans and the leaf tsb.
  9. Apr 4, 2010 at 2:24 PM
    #69
    freesample
    i took a differet route as i dont have a way of getting those o rings in lol. do the o rings end up inside or out side the factory rubber gasket?
    now for explaiing what i did..thats a different thing, i just put a pull tie arund the shaft comming from the engine bay and around one of the "bolts" extending from the dampening mechanism. and pulled tight. bascially it make the moving go completly to one range. mre then likely not as good as dalsmthme but i'm going to see how it pans out. went for a test run and it make 80 percent difference so far
  10. Apr 4, 2010 at 3:07 PM
    #70
    Canadianboy
    James
    Vancouver, BC
    Are you guys hearing any noise coming from the engine bay area when you hit bumps? I'm trying to figure out if the noise and rattling I've been hearing is the steering column moving around or some other suspension related problem I have yet to find.
  11. Apr 4, 2010 at 3:19 PM
    #71
    Faryota
    Faryota Well-Known Member
    Mic
    Ridgefield, WA.
    13, 4x4, long bed, Sport, Debad
    6" BDS lift in front, warn winch, AFE cold air intake & exhaust, Body Armor Rear bumper, Tuffy in bed storage box, DZ bed mat, ARB front bumper & Warn winch w/light kit, Husky floor mats, dash mat,
    Keep the info coming on this..I have never had any troubles yet?
  12. Apr 4, 2010 at 5:03 PM
    #72
    freesample
    its not so much as a noise issues as it is a loose feeling you get thouh the steering wheel. kinda a noise but like a knock
  13. Apr 4, 2010 at 5:04 PM
    #73
    docuw
    docuw Active Member
    SLC, UT
    09 Tacoma DBL TRD Offroad
    3" Lift: Front - OME 885 Springs with N140S, Toytec 1/2" Spacer; Rear - TSB Leafs with Toytec TSB AAL and OME N182S. Total Chaos UCA's, Access Tonnaeu Cover, Dynolock Tailgate Lock, Polished Aluminum Bull Bar, Bed Mat.
    mine does it too. on a long list of things i'd like to have fixed by Toyota. The two other major things are the creep while stopped issue where the transmission shifts or torque converter kicks in while stopped at a stop light and overcomes the amount of brake pressure that was previously adequate to stay stopped and the rig starts to creep forward. The other is the ABS brakes that activate so easily that while stopping quickly from about 15-20mph and hit some pot holes or bumps, and you can't stop the rig.
  14. Apr 4, 2010 at 7:52 PM
    #74
    freesample
    hey docu.. apparently there is a major fix for the tranmission... as for the abs... might depend on your tires
  15. Apr 6, 2010 at 7:33 AM
    #75
    dalsmthme
    Ithaca, NY
    When I was visiting my parents for easter, I took the opportunity to check my Father's '07 that does not exhibit the rattle. I found that his rag joint has the same motion mine does, the only difference is there is a LOT of grease packed down inside the joint. Mine was almost dry. Someone with a needle attachemnt for a grease gun could try filling the joint and see if it works.
  16. Apr 6, 2010 at 7:48 AM
    #76
    TOYOTA 09
    TOYOTA 09 Kicking Ass Since 1981
    Maine
    2009 SR5 MT 4x4 Access Cab
    Preview 2009 SR5 4x4 MT Black Sand Pearl (Access Cab) SUSPENSION ToyTec 5100 Billstein Coil Overs (3" Lift) Fox 2.0 Remote Res Rear Shocks Total Chaos UCAs Full Dakar Leaf Pack w/Extra AAL TIRES & WHEELS BFG AT KOs 265/75/16 load range E American Rancing AR-23 Wheels Borla CAT back exhaust AFE cold air intake w/custom TRD clear cover Satoshi grill w/Grill Craft insert Hella 500 behind grill lights Rigid Industries Backup lights Interior Custom LEDs and Bed Lights Backup Cam Anytime MOD Leather armrest and rear seat MOD Weathertech floor liners Custom rear gear/dog platform Cobra CB and Garmin GPS Bed Mat UWS low pro tool box with Custom LED lights Diff breather MOD Custom painted engine cover Wet Okole seat covers
    my truck does this on washboard dirt, or cobble stone roads....it's fine on regular pavement! Ahhhh! So the three fixes s far:
    insert rubber
    zip tie
    grease..
    anyone have luck making the dealer fix it?
  17. Apr 6, 2010 at 7:55 AM
    #77
    dalsmthme
    Ithaca, NY
    I originally brought it up with the dealer. They wouldn't work on it because another truck off the lot did the same thing. I don't think it would matter since it appears to be a design issue. They are just going to tear out your steering column and put in one that is just as bad. That is at least until a new design is available.
  18. Apr 6, 2010 at 9:46 AM
    #78
    TOYOTA 09
    Maine
    what about a TSB fix?
  19. Apr 6, 2010 at 10:30 AM
    #79
    dalsmthme
    Ithaca, NY
    I am not sure what you mean. There isn't a TSB.....
  20. Apr 6, 2010 at 10:56 AM
    #80
    TOYOTA 09
    Maine
    there SHOULD be!! Damn you TOYOTA!!
