Steering does not return to center
Discussion in '1st Gen. Tacomas (1995-2004)' started by SwampDeer, Aug 25, 2017.
  1. Aug 25, 2017 at 5:15 PM
    SwampDeer
    SwampDeer [OP] Active Member
    99 Tacoma 4x4
    3 inch lift.
    When I make a sharp turn 70°+ my steering does not return to center on its own. It is a 99 with a 2.7l 5spd 4x4. It came with and still has a 3" lift. ( spacers on the Coil springs) and it riding on31x10.5x15s. Is it a result of the lift, worn components or is this a tacoma thing? This is my first tacoma and first lifted truck. I'm trying to go over everything and maintenance/repair before hunting season starts. So I'm getting a 4x4 tacoma crash course.
    Thanks in advance
  2. Aug 26, 2017 at 12:04 AM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    Sounds like possible worn ball joints/tie rods. That'd be the first thing I'd check. Then delve deeper. Lifted that high increases the wear on those components first off, by a lot. Whens the last time they were replaced?
  3. Aug 26, 2017 at 12:13 AM
    Bishop84
    Bishop84 Well-Known Member
    Lack of caster can cause this. Excessive toe etc. Has it had an alignment performed since the lift?
    Dalandser likes this.
  4. Aug 26, 2017 at 4:16 AM
    SwampDeer
    99 Tacoma 4x4
    3 inch lift.
    The ball joints were replace just before I bought the truck.do im guessing 6 months. All other front end components aside from lift parts look factory
  5. Aug 26, 2017 at 4:22 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Spacer lift:facepalm:Not good. Get your front end checked out ASAP!
  6. Aug 26, 2017 at 4:22 AM
    Clearwater Bill
    Billy
    Largo Florida
    Cheap lift, lousy alignment.
    It 'may' not be possible to get a proper alignment w/o additional parts, like UCAs.
    A good alignment shop will be able to fill you in on that or any worn components that need replacing.
  7. Aug 26, 2017 at 5:45 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    This ^^^^
