STEERING FEEDBACK
Discussion in 'Suspension' started by FITTYGRIT, Aug 10, 2011.
  1. Aug 10, 2011 at 5:46 PM
    FITTYGRIT
    FITTYGRIT [OP] Member
    Kyle
    Missouri
    11 Tacoma DC TRD Off-Road
    Extand Trifold Cover, Husky Floor Liners, Bilstein 5100's @ 2.5" Rear TSB
    Guys I need some input/help. i have the 5100's and originally had them set at 1.75 and it rode really good, but then i moved them up to 2.5 and it rides like crap. Way to stiff, but I am also getting a lot of feedback/bumpsteer in the steering wheel when im on gravel or in the woods (even a slow speeds). My question is what is creating the feedback...the springs being really tight now or....the steering linkage being "tweeked" a bit by the lift. I am going to move the shocks back to 1.75 but if the lift isn't causing the steering issue I thought about putting the toytec 1/4" spacer on top to get most of the lift back and keep the ride nice.
    Also when I moved them to 2.5 I put on 16x9 wheels also. could the added track width cause some of that also?
  2. Aug 10, 2011 at 5:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Higher lift = less Caster, which then = more bump steer.
  3. Aug 10, 2011 at 6:15 PM
    FITTYGRIT
    Kyle
    Missouri
    the alignment wasn't perfect, but even the caster was in the "green". I really didn't think 3/4" would make THAT much difference, but I know everyone says the 2" mark is the magic # for UCA. DAMN.
