Steering feels different after aftermarket wheels and tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ted429, Nov 7, 2023.
  1. Nov 7, 2023 at 10:11 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    i bet the truck is fine. It's just the new offset and tires. My truck pulls to one side or another depending on road/ruts and can drastically pull when hitting the brakes on subpar pavement. But then I hit a nice piece of smooth highway and it'll track perfectly with hands off the wheel with zero pull.
    By pushing the tires out wider, you increase the leverage the road and tire applies to your steering, so it can substantially increase how much road surface effects your truck. And that's fine. Just be aware that your mods caused it, and you'll get use to it.
    Ted429[OP] likes this.
  2. Nov 7, 2023 at 10:21 AM
    Brianz1001
    Brianz1001 Well-Known Member
    Brian
    Retired on my couch with a cold beer in my hand
    too much to type
    I didn’t say it would just asking, could be a bad tire also. If alignment was good before you can’t blame the truck, larger tires and aftermarket rims were just installed, process of elimination.
  3. Nov 7, 2023 at 10:51 AM
    Slow_sr20
    Slow_sr20 Well-Known Member
    23’ DCSB O/R
    Check alignment 1st. Next step would be to “cross rotate” your front tires (swap L/F and R/F). Tires can cause a pull. If you cross rotate and the truck goes the other way it’s a tire issue. If it doesn’t then you can play with alignment specs to force it to go straight, but that may effect tire wear.
    If all that fails, then chalk it up to more contact patch and a grabbier tire creating the sensation.
  4. Nov 7, 2023 at 11:16 AM
    Bill0351
    Bill0351 Well-Known Member
    Bill
    2023 SR V6 4x4
    Tires/Cap
    I went from the standard SR tires to +1 Duratracs.
    Wanders, bounces, and pulls you down the crown a lot more than the stock ones. Not bad at all, but a definite change. Same as when I did something similar with my 4-Runner. I wouldn’t worry about it.
  5. Nov 7, 2023 at 6:19 PM
    camposme
    camposme Well-Known Member
    Ty
    Piedmont Triad - NC
    '16 TRD Sport DCSB
    Fox 2.5 Racing Suspension w/ Resi (ET) OME Dakars (Med Duty) SPC UCAs BAMF Grille TRD Skid TRD Wheels Tom Woods DS
    These trucks love caster. Keep it at 3+ and it will feel like rails... well, for a Tacoma anyway lol
  6. Nov 28, 2023 at 11:15 AM
    Ted429
    Ted429 [OP] Member
    2023 Tacoma TRD Sport Lunar Rock
    Just updating this thread to let everyone know that I took the truck to Toyota for the 10k service and mentioned the pull to the right. They checked and said it was out of alignment, they even swapped my front tires to see if that was the issue. Tires are fine and an alignment performed. Night and Day difference. I am just confused on if it was actually bad from the factory or if swapping tires really caused the truck to drive so different.
    Also they did everything under warranty no charge no questions asked. :)
    Tocamo and Bill0351 like this.
  7. Nov 28, 2023 at 11:52 AM
    2013logan
    2013logan Active Member
    New Mexico
    2019 Tacoma TRD pro
    icon add a leaf, KD max tune,RSG sliders, Falken 33inch MT, eibach spring, arb front locking diff,ARB air compressor.baja designs squadron fog lights non dot comliiant.
    I have worked as a mechanic for years and that is why I recommend you align your truck it will prolong your tires and make sure there is nothing going on with your toe angle causing it to pull I know it sucks to pay 100 dollars for something that isnt tangible but it is 100 percent worth the money and firestone used to due a lifetime alignment deal that lasts for the life of your car or truck
