Steering grabbing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bowhunter74, Apr 4, 2023.
  1. Apr 4, 2023 at 2:12 PM
    Bowhunter74
    Bowhunter74 [OP] Well-Known Member
    Had this problem a few months ago which completely resolved with a power steering fluid flush. Started again recently. Steering “grabs “ randomly at all speeds. Might turn smoothly, then grab and get tight, then release. Fluids are at max (dexron). Is power steering pump the most likely culprit?
  2. Apr 4, 2023 at 2:21 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    May want to check the knuckle on your lower intermediate steering shaft!
    They rust and bind.
    Mine had lack of return to center.
    Bowhunter74[OP] and Steves104x4 like this.
  3. Apr 4, 2023 at 2:49 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Lower steering shaft u-joint. Hit it with some penetrating lube like wd-40, if it smooths out you found the problem. Lubing it once or twice is OK, if it keeps binding it should be replaced
  4. Apr 5, 2023 at 9:51 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    NO DONT USE WD40 its to dry wires aka WATER DISPLACER 40th try. The oil evaporates faster than diesel fuel
    soak it in engine oil or use penetratinng oil or PBBlaster
  5. Apr 5, 2023 at 9:56 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    OMG :goingcrazy:
  6. Oct 6, 2023 at 6:04 PM
    Bowhunter74
    Revisiting this thread. I did the PB blaster trick, which worked for a couple months. Today I tried to replace the shaft but ran into an issue when trying to lower the steering rack mount. The driver side bolt is in upside down and won't come out unless I cut it (or remove parts of the engine--no thanks). Anyone know what this part number is? It's the long 5-6" 17mm bolt.
    Thanks.
