Steering help
Discussion in '1st Gen. Tacomas (1995-2004)' started by fouillard13, Mar 24, 2014.
  1. Mar 24, 2014 at 5:50 PM
    fouillard13
    fouillard13 [OP] Well-Known Member
    Riley
    Canadia
    1998 tacoma 4x4
    I just bought a 95 tacoma 3.4 auto that had bad steering
    The fluid is full!
    The issue is that it steers like crazy all over the highway and it whines when turning. Also the steering is super stiff unless you are accelerating orvwhencrpm increase.
  2. Mar 24, 2014 at 5:53 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    If the fluid is full make sure the power steering pump is good and the rack is good. Maybe someone else will chime in that knows a bit more.
  3. Mar 24, 2014 at 5:55 PM
    fouillard13
    Riley
    Canadia
    1998 tacoma 4x4
    Previous owner told me "steering box" I use to do one on my old jeep tj do to leaking. I will check the front end over. I'm leaning towards pump or rack.
  4. Mar 24, 2014 at 7:07 PM
    fouillard13
    Riley
    Canadia
    1998 tacoma 4x4
    I read there is a filter in the bottom of the reservoir that can get clogged
  5. Mar 24, 2014 at 9:07 PM
    somethinboutayota
    somethinboutayota Dorthy left Kansas for a reason
    Parker
    Dodge City, Kansas
    Go to get alignment- replace whole front end
    Debadged and painted, plasti-dip bumper , Sock monkey decals, tool box, K&N cold air intake, flag holder/fishing pole holder, Satoshi, magnaflow 40 series, spidertrax wheel spacers, map lights, led reverse lights, led dash assembly lights, roof top LED bar
    Sounds like you need a new steering pump, or possibly a new rack. Have a local mechanic check it out for $10 or so to be safe, it'll save you some time
  6. Mar 25, 2014 at 7:33 AM
    tonymhouts
    tonymhouts Active Member
    Wisconsin
    97 Toyota Tacoma
    low profile front/rear bumper, coil overs, 3 inch lift.
    I know I had just replaced my rack and pinion because it was nearly impossible to turn left but could turn right just fine.
    But then I messed up when it came to bleeding it. I used Lucas Power steering fluid to fill up the system, (I used the stuff when it came to needing to top off the resevoir before hand). Problem came when I bought all the fluid days before I did the project and let it sit in my truck in the freezing cold that is Wisconsin. fluid was gel like and couldn't properly bleed it. Live and learn project for me. I think I blew out the pump. Just waiting for it to get a little warmer before I test that. I can turn just have to put some man into it.
    It's my highly amateurish opinion that if you are getting a noise that the pump is working, but there is a fluid issue, screen being clogged, etc. I get no noise from my pump, so that's why I'm thinking it's bad.
  7. Mar 27, 2014 at 1:22 PM
    fouillard13
    Riley
    Canadia
    1998 tacoma 4x4
    My power steering does not work at idle. I'm wondering of it's the idle up valve I have read about
  8. Mar 27, 2014 at 1:25 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    If its whining and hard to turn. Id put my money on the pump. Mine whines like crazy when im in 4lo and crawling for hours.
    How many kms on it? Original?
  9. Mar 28, 2014 at 12:13 AM
    fouillard13
    Riley
    Canadia
    1998 tacoma 4x4
    174 k miles
    Pump works awesome when driving or above 1200 rpm
  10. Mar 28, 2014 at 9:13 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Sounds like you have 2 issues, pump and rack.
    Check the fluid immediately after driving it. Does it look frothy?
    You could have bad TRE's, thats causing the wandering. Have it checked out.
    You can do this by lifting up one front corner at a time (tire off the ground), grabbing the tire at '9 and 3' and try to detect wobbling.
  11. Mar 28, 2014 at 5:28 PM
    fouillard13
    Riley
    Canadia
    1998 tacoma 4x4
    Both inner tierods were absolutely shot sitj 1 inch of play on each wheel. I ordered new brakes and. Ties rods from summit. I think my only other issue is powersteering not working at idle
  12. Mar 28, 2014 at 10:05 PM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    What does frothy mean.. :/
  13. Mar 29, 2014 at 9:33 AM
    tan4x4
    Rick
    Folsom, CA
    foamy ?
    When the pump is trying to include air along with the fluid, bubbles are inserted, and the dark red becomes pinkish and bubbly. This can happen because of an air leak, low fluid, or clogged reservoir screen.
  14. Mar 29, 2014 at 10:01 AM
    garrettnb
    garrettnb Canadian Ambassador
    Garrett
    Vancouver
    00 TRD w/33s on a 4" lift
    I have had every steering issue under the sun and kind of declare myself to be an expert in the first gen power steering system.
    First thing first, ditch the lucas power steering fluid (use the low pressure return to get rid of everything). Get yourself some ATF which is what it should be. Then buy twice as much as you need, if you're a stickler get some cheap stuff from walmart and do a flush with that and then use your favourite flavour after that. I personally don't see any difference and use cheap walmart fluid permanently.
    Before you refill the fluid you can either rip apart the resevoir (rather difficult) and it's even more difficult when the pump is on the truck. But its up to you, If you grab a big long flat screwdriver with some paper tower or something wrapped around the end you can remove a lot of the gunk that's on the screen. Just use a light to look inside the hole. It's a pain in the ass, but with time and care it can be done. BE CAREFUL not to puncture the screen. Some people just skip cleaning the screen and jam the screwdriver right through it. But this can introduce the grime through your PS steering and cause even more issues.
    The pump whining could be caused by air in the system, or more than likely the pump causing cavitation because it is being starved for fluid due to the screen being clogged.
    If none of these things help you, then you can try your luck with a cheap used pump from a wrecker. I bought one that had 80k miles on it for $35 and it cleared up all my issues.
  15. Mar 29, 2014 at 3:49 PM
    fouillard13
    Riley
    Canadia
    1998 tacoma 4x4
    Hmm ok thanks I will try that
    Would someone say my pump is shot? The fluid was very dirty. Works fine except at idle
  16. Mar 31, 2014 at 7:37 PM
    fouillard13
    Riley
    Canadia
    1998 tacoma 4x4
    Drained fluid added new stuff cleaned res bottle still wines and you can feel the bump vibrated when you put your hand on resivoir bottle
  17. Mar 31, 2014 at 8:22 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    The filter in the reservoir could be gunked up...
  18. Mar 31, 2014 at 8:23 PM
    fouillard13
    Riley
    Canadia
    1998 tacoma 4x4
    Just cleaned that completely. Pump hums even at idle
  19. Apr 1, 2014 at 9:20 PM
    fouillard13
    Riley
    Canadia
    1998 tacoma 4x4
