Steering issue after SEMA wheel install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rtw07, Apr 16, 2019.
  1. Apr 16, 2019 at 6:44 PM
    rtw07
    rtw07 [OP] Well-Known Member
    Myrtle Beach, SC
    2018 Tacoma TRD Sport
    I purchased SEMA wheels for my 18 Sport during the 40% sale and had them installed last week. They swapped over the OEM tires with 15k miles on them. Since then, I've noticed what feels like a shake in the steering wheel while cornering. Only feel it while actually moving the wheel. Straight-line travel and consistent cornering, I don't feel it. Thoughts?
  2. Apr 16, 2019 at 6:47 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Is it at all speeds or only certain speeds?
    Are the wheel setups lighter or heavier over OE?
  3. Apr 16, 2019 at 6:48 PM
    Hstone556
    Hstone556 Ain’ters gonna ain’t
    Hunter
    Austin
    2019 Ram 2500 Laramie
    Raceline 17" Gauge's 37x12.50 Toyo's RT, Carli King 2.5s
    Gotta look into the only change point, the wheels... was an alignment done? If not most probable is a balance issue. Swap wheels/tires from front to back and retest.
    Gunshot-6A likes this.
  4. Apr 16, 2019 at 6:49 PM
    rtw07
    Myrtle Beach, SC
    Mostly notice it over 20 mph. I believe they are a little lighter than the OEM wheels.
  5. Apr 16, 2019 at 6:50 PM
    rtw07
    Myrtle Beach, SC
    Alignment wasn't completed. I actually had the tires rotated at my 15k service a few days after having the wheels installed and I noticed it before and after. If it was a balance issue, wouldn't I feel it during straight travel as well?
  6. Apr 16, 2019 at 6:51 PM
    Hstone556
    Hunter
    Austin
    Hmm, that’s interesting.
  7. Apr 16, 2019 at 7:00 PM
    gamerunner
    gamerunner Well-Known Member
    2018 TRD OR
    TRD Pro grill
    Do pro wheels use the same lugnuts as your sport wheels? If so, maybe have them pulled off and re-torqued?
  8. Apr 16, 2019 at 7:02 PM
    rtw07
    Myrtle Beach, SC
    They used the same lugs. I might swing it by the shop that installed the wheels this week sometime. If they don't see any problems, I'll drop it off at Toyota.
  9. Apr 16, 2019 at 7:45 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Check your lug bolts, make sure they are tight.
    JimmyRigged88 likes this.
  10. Apr 16, 2019 at 7:51 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Probably warped the front brake rotors when they socked the lugs nuts on with an impact wrench...or TPMS sensor is broken off inside the wheel throwing the balance off.
  11. Apr 17, 2019 at 7:22 AM
    5nahalf
    Erik
    Minnesota
    Warped rotor would not be present unless braking, and tpms sensor would give a shake at all times.
    Couple things to keep in mind
    shake at highway speed = unbalanced
    shake that comes and goes depending on speed (usually from 55-75) = hubcentric rings needed (usually only for aftermarket wheels)
    shake while cornering with possible clicking sound straight at low speed = loose lug nuts
    vibration that gets louder or softer depending on what way your turning = wheel bearing
    constant vibration/loud rumble = tires cupped or feathered
    clicking while turning only = bad cv joint
    whole body shaking like hell aka "death wobble" = never buy a jeep
  12. Apr 17, 2019 at 8:16 AM
    ArmandHammer83
    ArmandHammer83 This truck is AMAZING
    Raymond
    Alabama
    2018 Tacoma AC V6 MT 4x4
    none yet
    not gonna lie learned a couple things on this post
  13. Apr 17, 2019 at 9:56 AM
    cstern1
    cstern1 Well-Known Member
    Caleb
    KCK
    2017 DCSB Sport
    I also have an issue after the SEMA wheels were installed on my factory sport tires. I had them installed while doing the 15k service at the dealer. Also had an alignment done.
    My steering wheel seems to have way more feedback in it now, kinda shaking from side to side some while at highway speeds. My first thought is check the lugnuts since it was done almost a week ago. Seems like the problem crept up in the past day or so. Kinda forgot to do it last night.
  14. Apr 17, 2019 at 10:01 AM
    Tacoma2020
    Tacoma2020 Well-Known Member
    So, no balance and alignment since the install?
  15. Apr 17, 2019 at 10:20 AM
    rtw07
    Myrtle Beach, SC
    They balanced when the wheels were installed but did not do an alignment. I just went by the shop and they said it’s probably alignment. They didn’t realize the offset was different when I had them install them. I’m dropping it off in the morning for them to check the alignment.
    Tacoma2020[QUOTED] likes this.
  16. Apr 17, 2019 at 10:42 AM
    5nahalf
    Erik
    Minnesota
    If yours was fine for a little while, then started to wobble at highway speed then a weight may have come off. This will be hard to check, but if you look inside the wheel there may be a clean square of wheel where a weight used to be (though it might be from the old weights)
  17. Apr 17, 2019 at 10:43 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Tire shop didnt balance the wheels properly.
    Bastek likes this.
  18. Apr 17, 2019 at 10:50 AM
    cstern1
    Caleb
    KCK
    2017 DCSB Sport
    There wouldn't have been any weights previously on new wheels. Mine feels more like tramlining where the road causes it to wander. Will check the weights though.
  19. Apr 17, 2019 at 11:02 AM
    5nahalf
    Erik
    Minnesota
    Could possibly be related to the increased width of the track. I believe those wheels have a different backspacing than the oem sports, giving you about .9 inches wider on each side. Possible that the increased track is not playing well with the sport tires.
    edit
    "Increased Wheelbase: Wheelbase is the distance between the wheels on the same axle. The tramlining effect increases as the wheelbase increased. If you install wheel spacers to move out the wheels little for stance or handling purpuse, remember that it will increase the chances of tramlining."
    https://motoringjunction.com/tips-tricks/what-is-tramlining-and-how-to-avoid-it-dangerous/
  20. Apr 17, 2019 at 11:09 AM
    cstern1
    Caleb
    KCK
    2017 DCSB Sport
    They do create a wider stance. May need a different alignment setting to negate the tramlining
