Steering Issue with a 2011 Trd Double Cab
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wildtrt, Jan 25, 2011.
  1. Jan 25, 2011 at 7:55 PM
    wildtrt
    wildtrt [OP] Active Member
    TXPRO
    Hi Guys just bought a 2011 TRD Double cab. It has the TxPro package on it. It's great but I have a weird steering issue. When I am on rough terrain like the road I live on the steering feels real loose on the bumps. Almost feels like it disconnects or something. Also when I shift into 4h there is a loud 'clunk". Dealer said that this is a break in situation. I can buy that w the 4 wheel but the steering is just plain funky.
    Any body have any experience with this?
    Thanks
  2. Jan 25, 2011 at 8:19 PM
    Sheppymach
    Sheppymach Well-Known Member
    Sheppy
    Philadelphia, Pa
    2014 4Runner trail edition
    BLU LOGIC bt, avid, weather tech mats & rain guards, 285/70/17, BenWA's totally AWESOME power sliding window mod.
    T-SB-0119-10
    give me a minute and ill pull it off alldata. i just dropped mine off to get replaced tomorrow
  3. Jan 25, 2011 at 8:19 PM
    ckeeton
    ckeeton Bazinga
    Duluth, GA
    2011 DC Trd Sport Gray
    trd sport with avid off road light bar, avid rock sliders. OEM roof rack, 12' LED light bar, and Sock monkey decals.
    i have the 2011 DC sport and no problems with the wheel on or off the road. could either by just a bug with yours or something up with that package. never driven one so i dunno
  4. Jan 25, 2011 at 8:22 PM
    Sheppymach
    Sheppy
    Philadelphia, Pa
    T-SB-0119-10
    Rev1
    May 3, 2010
    Steering Intermediate Shaft Rattle Noise
    Service Category
    Steering
    Section
    Steering Gear/Linkage
    Market
    USA
    Applicability
    TSB REVISION NOTICE
    May 26, 2010 Rev1:
    ^The Op Code has been corrected in the Warranty Information table.
    Any previous printed versions of this service bulletin should be discarded.
    Introduction
    Some 2005 - 2010 model year 4WD Tacoma and 2WD Tacoma PreRunner vehicles may exhibit steering rattle noise when driven over rough road surfaces. A newly designed steering intermediate shaft has been made available for service to address this condition.
    APPLICABLE WARRANTY
    ^This repair is covered under the Toyota Comprehensive Warranty. This warranty is in effect for 36 months or 36,000 miles, whichever occurs first, from the vehicle's in-service date.
    ^Warranty application is limited to occurrence of the specified condition described in this bulletin.
  5. Jan 25, 2011 at 8:23 PM
    Sheppymach
    Sheppy
    Philadelphia, Pa
    Repair Procedure
    Note
    Prior to removing the steering intermediate shaft, make sure the steering wheel and front wheels are straight and remain stationary. Once the intermediate shaft is removed, do NOT allow the steering wheel to spin freely. Use a steering wheel holder to keep the steering wheel from turning.
    1.Install a steering wheel holder.
    2.Remove the steering column hole cover by disengaging the 4 clips.
    3.Put matchmarks on the intermediate shaft.
    4.Remove the one bolt that attaches the intermediate shaft to the steering column and discard the bolt.
    5.Access the intermediate shaft from the driver's side engine cover and remove the 2 clips that hold the engine cover.
    6.Put matchmarks on the intermediate shaft as shown.
    7.Remove the upper bolt that attaches the intermediate shaft No.1 to the intermediate shaft No.2.
    Loosen the lower bolt then slide the shaft up and out.
    8.Place matchmarks on the NEW intermediate shaft.
  6. Jan 25, 2011 at 8:53 PM
    wildtrt
    TXPRO
    Thanks appreciate the advise.
  7. Jan 25, 2011 at 8:55 PM
    wildtrt
    TXPRO
    Thank you so much. I knew it was a little to funky to be normal. I'm taking it in tomorrow.
  8. Jan 25, 2011 at 10:30 PM
    Sheppymach
    Sheppy
    Philadelphia, Pa
    No prob. At first the serv rep told me it would go away when leaf spring was added. I laughed out loud and told him nope it doesnt work that way. Explained nicely how rag joint/intermediate shaft worked and then pulled out all 8 pages of tsb. He walked away nicely after ordering new shaft. Parts installing tomorrow. Ill let you know new feel after i get it home, the long off road way home
  9. Jan 25, 2011 at 10:40 PM
    wildtrt
    TXPRO
    Thats great, good call having the TSB with you. I'll have it with me tomorrow also. Def. let me know how it turns out. I am sure I have the same situation.
