Steering issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by dan476, Jun 29, 2012.
  1. Jun 29, 2012 at 7:31 PM
    dan476
    dan476 [OP] Well-Known Member
    Did a little bit of off-roading today, nothing crazy, but when I was hitting uneven surface, it felt as if my steering was loose at times. Steering wheel would hit "pockets" and lose any resistance for a short time. Hope someone knows what I mean and can tell me what could be wrong.
  2. Jun 29, 2012 at 7:56 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    Maybe you're low on fluid, sounds like air in the system maybe? Is it whining at all?
  3. Jun 29, 2012 at 8:19 PM
    dan476
    No whine at all and fluid is fine. it only happends when I hit bumps, feels like too much play in the steering.
  4. Jun 29, 2012 at 8:26 PM
    Supra TT
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    Climb under there and take a look, maybe you have a messed up tie rod? I've never been too familiar with the stock steering.
  5. Jun 30, 2012 at 8:40 PM
    dan476
    Tie rods are fine, fluid is fine as well, any other reasons why I would feel looseness in the steering while hitting bumps?
  6. Jun 30, 2012 at 8:53 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I would take it to a reputable shop and have them look at it or you may be sorry. Check other thread for "lost wheel at 70 mph"
  7. Jul 22, 2012 at 8:37 AM
    urby2112
    urby2112 Active Member
    Surprise,AZ
    2000 Prerunner TRD Xtra Cab
    Bilstein 5100/5125's, 15x8 Eagle alloys 31x10.5 BFG ATKO's, Magnaflow, K&N, Airaid intake, Jet TBS.
    Check the bushings on the rack itself if your BJ's and TR's are ok. At 150K I noticed the whole rack on mine actually moved like 1/4 ". Carquest had a kit from Raybestos for $25. Made a huge difference! There are actually 5 bushings in the kit (the big one on the passenger side, upper and lower for center, and front and rear for drivers side). Came with washers and new bolt sleeves.
