Steering issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sarah, Nov 2, 2017.
  1. Nov 2, 2017 at 4:27 PM
    Sarah
    Sarah [OP] Member
    Sarah
    Blue Tacoma trd sport and 1984 black land cruiser
    My steering is a little loose
    A little play, about in inch in the steering wheel, side to side
    Also, it seems slightly tighter when I turn
    It has always driven very straight
    Any ideas as to what is going on?
    Thanks in advance
  2. Nov 2, 2017 at 4:29 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    Hello Sarah, what truck do you have? 5 or 6 lug?
    Inner tie rod ends
    Outter tie rod ends
    steering rack bushings
    steering rack
    rack guide
    upper ball joints
    lower ball joints
    Wheel bearings
    intermediate steering shaft joint slop
    intermediate steering shaft slip joint slop
    It really could be a lot of things. That will get you started.
    ChadsPride and Sarah[OP] like this.
  3. Nov 3, 2017 at 1:39 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If I were to guess I would say the weak point is the Steering Intermediate Shaft Assembly universal joint. It is exposed to the harsh elements under the truck and tends to get worn out and rusty. This could cause slop and tight spots when turning.
    Sarah[OP] likes this.
  4. Nov 9, 2017 at 10:03 AM
    Sarah
    Sarah [OP] Member
    Sarah
    I’m not sure how many lugs, I’ll have a look
    And thank you both for your replies
    I’m going to get new studded winter tires on and maybe they can let me know if anything is out of sorts
  5. Jan 5, 2018 at 10:12 AM
    Sarah
    Sarah [OP] Member
    Sarah
    Thank you very much for your replies :)
    It was the steering intermediate shaft assembly
    Got it replaced and it’s great now
    Jimmyh and Greensystemsgo like this.
  6. Jan 5, 2018 at 1:15 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    Glad you got it figured, its a commonish problem especially for trucks in wet/cold/salt environments.
  7. Jan 5, 2018 at 3:05 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    :thumbsup:
