Steering Issues
Discussion in 'General Tacoma Talk' started by FishWolf, Oct 31, 2023.
  1. Oct 31, 2023 at 11:06 AM
    FishWolf
    FishWolf [OP] Well-Known Member
    R Something
    2011 Toyota Tacoma
    Total Chaos Urethane Upper Control Arms FOX Factory Series 2.5 Remote Reservoir Front Coilover Shocks FOX Factory Series Remote Reservoir Rear Shocks 1-1/2” Rear Lift Block Kit Nitto EXO Grappler Tires (285/70R17) Method Fat Five Wheels – Custom color (17x7) Warrior Products Front Winch Bumper w/ D-Ring Mounts & Brush Guard Wurton 5” LED Light Bar (pair) – Installed in Front Bumper Warn Zeon Winch w/ Steel Cable & Fairlead (installed in Front Bumper) Warrior Products Rear Bumper w/ Integrated Hitch and D-Ring Mounts Wurton Scout Series LED Cubes (installed in Rear Bumper) Warrior Products Bolt-On Side Steps Warrior Products Platform Roof Rack Warrior Products Platform Air Dam Warrior Products Bed Rack Warrior Products Bed Support Tie Bar for Warrior Products Tacoma Bed Rack Bolt-On Spare Tire Mount (installed on Bed Rack) Warrior Products Black Diamond Plate Aluminum Tailgate Trim Warrior Products Black Diamond Plate Aluminum Sideplates Warrior Products Black Diamond Plate Aluminum Entry Guards sPod Switch Panel and Relay Kit Borla Cat Back Exhaust System Custom Vinyl Wrap
    Im having a issue where my steering feels loose and have to constantly adjust on highway, with steering wheel shake at certain speeds, also any little bump etc makes steering wheel jump around, ive just had a bunch of front end work but still same issue, replaced all shocks, new upper control arms, new inner/outer tie rod ends, new sway bar end links, new sway bar bushings, and also new alignment. Ive read that a common issue can be the upper or lower intermediate steering shaft, it describes same issues im having including a clunk sound under dash area, any opinions or advice on this would be great, thanks in advance
  2. Nov 1, 2023 at 2:05 PM
    uppersalmon
    uppersalmon Member
    Newfoundland canada
    2012 TRD 4X4 TACOMA
    I got a issue with my 2012. Noticed a little play in steering wheel. Got a bad universal in lower steering shaft. Got a new one ordered but like to get a universal to repair the stock shaft. That don’t solve you problem. I recommend you go on YouTube and watch some videos on replacing the upper and lower shaft. There you will see the shafts better and the wear points. So you can trouble shoot and find the problem if it is in the shafts.
    FishWolf[OP] likes this.
