Steering Knock (with video)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by regtaco, Mar 9, 2012.
  1. Mar 9, 2012 at 1:47 PM
    regtaco
    regtaco [OP] Well-Known Member
    Lee
    Knoxville/Franklin TN
    07 Reg cab 4x4
    Toytec 3 inch lift kit with: OME 884 coils, OME Nitro shocks, custom driveshaft, diff drop
    Hey guys, I'm new at this forum but have been over at ToyotaNation for quite some time. Looking forward to getting to know everyone here.
    Your help will be appreciated with this one... within the past week my steering has developed a "knock" sound when I move the steering wheel back and forth. The truck has right at 50,000 miles. I've tightened the steering rack bolts, flushed and refilled the power steering fluid, checked all of the ball joints, and the steering shaft u-joints. The u-joints have no play in them that I can tell.
    Attached is a Youtube video of the sound... If I can't figure this one out its off to Toyota.
    http://www.youtube.com/watch?v=2OhTFLSGBio&feature=player_embedded
  2. Mar 9, 2012 at 2:15 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    interesting. if i were you id get a mechanics stethescope and start probing
  3. Mar 10, 2012 at 2:49 PM
    regtaco
    Lee
    07 Reg cab 4x4
    Thanks for the tip fixer5000. Ill do that tomorrow when I have the time. Anyone else have a clue as to what this could be?
  4. Mar 10, 2012 at 3:02 PM
    Bosmob
    Bosmob Well-Known Member
    Kevin
    San Diego, CA
    '11 Access Cab SR5 I4 4AT
    Fat Bob's 2.75" front spacers Magnaflow Muffler Doug Thorley Header ImMrYo Mirror Bracket
    Sounds like your intermediate shaft is giving out.
    I would check that out.
    Also, there's no need to run out and buy a mechanics stethoscope, just use a good size length of fuel hose or even a long screwdriver to listen in for sounds.
  5. Mar 10, 2012 at 3:23 PM
    regtaco
    Lee
    07 Reg cab 4x4
    Thanks Bosmob, I will definitely look into that. Thanks for saving me money on the stethoscope too!
  6. Mar 10, 2012 at 3:42 PM
    fixer5000
    massachusetts
    no offense but a stethescope works 100 times better and youll always have a use for one. they can be had cheap too. hows your hose work close to an idler pulley? still got all your fingers?
  7. Mar 10, 2012 at 4:10 PM
    regtaco
    Lee
    07 Reg cab 4x4
    PSUTaco85, have you had this problem in the past? The knock sound is getting louder and its driving me nuts. Fixer5000, I think your right in that the 20 bucks for a stethoscope isn't bad... I was thinking it would be a lot more expensive. But Bosmob's idea worked for now.
  8. Mar 10, 2012 at 4:19 PM
    regtaco
    Lee
    07 Reg cab 4x4
    Cool, thanks. Like that flex in your pic btw.
  9. Mar 10, 2012 at 6:44 PM
    Bosmob
    Kevin
    San Diego, CA
    That's what the screwdriver is for...
    I understand a stethoscope will work better, but I'm trying to save the OP time and money so he can figure out the problem quicker.
  10. Mar 11, 2012 at 4:33 PM
    regtaco
    Lee
    07 Reg cab 4x4
    Well I pulled off the tie-rod boot to have a look inside, and from what I can tell the inner tie-rod looks fine. I haven't done any tie-rod work before so I posted another video with the boot off so you guys could take a look. If I can figure this out I'll post a DIY thread for the fix.
    https://www.youtube.com/watch?v=0uB86ruIblE
  11. Mar 11, 2012 at 10:47 PM
    Bosmob
    Kevin
    San Diego, CA
  12. Mar 12, 2012 at 2:21 PM
    regtaco
    Lee
    07 Reg cab 4x4
    Bosmob, you are the man! Thanks for finding that video and all your help. I guess I will pull my intermediate shaft off sometime this weekend and will go from there.
  13. Dec 11, 2013 at 9:12 PM
    ToyoTaco06
    ToyoTaco06 Active Member
    BC
    06 Tacoma SR5 Short box
    6" Lift, 35's
    hey, don't know if your still having this issue, but i have an 06 dc with 110 000 miles and i have the clunk and play in the steering. I pulled the boot off and noticed that my rack has the same rack guide slop that the 04 and previous years had. Ive been looking for a guide kit to avoid the dealership but i think getting the cap and spring and guide through them is the only option.
    Little bit of a different rack but same idea as on 05+
    Found this through the Google:
    http://www.yotatech.com/f2/how-replace-steering-rack-guide-pictures-215931/
  14. Dec 12, 2013 at 5:07 AM
    regtaco
    Lee
    07 Reg cab 4x4
    ToyoTaco,
    I ended up strapping down the rag joint on the intermediate shaft with zip ties instead of replacing the whole thing. When I pulled off the plastic cover inside the cab, I found lot of play around the rag joint, and searched this forum for a solution.
    I'm leaving for work now, but will try and find a link to share when I get home. While not the most recommended of solutions, I've put about 20,000 miles on the truck since the zip tie fix without one problem.
  15. Oct 26, 2015 at 8:06 PM
    EB Group
    EB Group Carbon Jedi
    Rudy
    Halifax
    2017 TRD Sport DCSB 6M
    Has anyone actually solved this issue?
    I am having the same thing going on.
  16. Oct 27, 2015 at 8:00 AM
    regtaco
    Lee
    07 Reg cab 4x4
    I ended up strapping down my rag joint with zip ties and putting a piece of credit card inside the center of the rag joint. Definitely a sketchy fix but that seemed to fix it. I've put 40k miles on the truck since I did that and the sound is gone. I've gone off-roading multiple times since the fix and the zip ties haven't budged.
  17. Oct 27, 2015 at 1:54 PM
    EB Group
    Rudy
    Halifax
    Thank you for the update regtaco!
    I do not think my issue is having to do with the rag joint or mid steering shaft.
    I'll keep this thread updated with my findings.
  18. Oct 27, 2015 at 2:29 PM
    regtaco
    Lee
    07 Reg cab 4x4
    If you take off the plastic cover under your dash and shake the intermediate shaft at or near the rag joint and there is a lot of play, that's your issue. I checked everything (ball joints, UCA and LCA bushings, steering rack, tie rod ends, etc) before finally figuring it out.
  19. Oct 27, 2015 at 2:44 PM
    EB Group
    Rudy
    Halifax
    I will check that, I am not experiencing any knock while turning the steering wheel. Only over bumps and when I lift the passenger tire off the ground and push on the tire at the three oclock and 9 oclock position.
  20. Oct 27, 2015 at 2:56 PM
    regtaco
    Lee
    07 Reg cab 4x4
    Ah well my guess is inner or outer tie rod. The ball joints on our Tacomas (in my experience) are indestructible.
