Steering knuckle long travel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TankTop, Sep 7, 2018.
  1. Sep 7, 2018 at 3:03 PM
    TankTop
    TankTop [OP] Well-Known Member
    2007 Tacoma
    Long travel, Fox 2.5, ARB bumper and lockers, 4.88 gears and 35’s plus more
    Broke the lower uniball stud but when when the shop took the wheel off they noticed it had weld on spindle gussets that had been cut out to fit 35x12.5’s. On side of the spindle had also cracked all the way through.
    TireFire[QUOTED] likes this.
  2. Sep 7, 2018 at 3:04 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Yes, now shush and go away
  3. Sep 7, 2018 at 3:06 PM
    TankTop
    2007 Tacoma
    I started the thread because there is very little information on steering knuckles for long travel suspension but lots of companies sell weld on spindle gussets.
    Anyway, I almost feel like calling the police to report myself because I absolutely stole the truck, that sad all I bought was a hole in the ground that I’m gonna throw money into!!!
  4. Sep 7, 2018 at 3:07 PM
    TireFire
    Olympic Peninsula
    Gotcha, thanks.
    It sounds like the gussets were improperly welded. I'm only on 33's but bolted on a 35 for shits and giggles and the tire easily clears my gussets.
    If you spindle isn't bent you could just grind off the old crappy gussets. The Dorman ones you linked will work but certainly are no upgrade
  5. Sep 7, 2018 at 3:10 PM
    TireFire
    Olympic Peninsula
    There really aren't any aftermarket off the shelf spindles for 4x4 Tacos. It's all custom if you wheel that hard.
    And the spindle has no real bearing on the travel you can pull
  6. Sep 7, 2018 at 4:32 PM
    TireFire
    Olympic Peninsula
  7. Sep 7, 2018 at 4:34 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Bent or tweaked gussetted spindles are fairly common. But sounds like by your description that the gusset itself has been modified in a fashion that is not recommended by any manufacturer.
    Still, doesnt deter from what appears to be a sheared lower uni-ball bolt. That bolt by itself does not attach to the spindle, it attaches to the lower arm and to the uni-ball cup adapter.
  8. Sep 7, 2018 at 4:37 PM
    MonkeyProof
    SoCal- SGV
    I wonder if the uni-ball cup adapters are installed in the correct position..
  9. Sep 27, 2018 at 5:04 PM
    TankTop
    2007 Tacoma
    Got it back yesterday, ended up replacing the knuckles and both lower uniballs and adding limiting straps. FWIW AllPro is not the best to deal with from my experience, i’m not saying I would write them off entirely but they may be going through a difficult time right now. Hopefully I can get out for a couple hours this Sunday and stretch its legs a little, maybe long water
    Blandino likes this.
  10. Sep 27, 2018 at 5:28 PM
    MonkeyProof
    SoCal- SGV
    You are not dealing with AllPro, they have been bought out by Trail-Gear. It is Trail-Gear that you are now dealing with.
  11. Sep 27, 2018 at 5:37 PM
    TankTop
    2007 Tacoma
    That makes a lot of sense. The bolts on both lower ball joints were worn in a similar pattern, I think I’m going to order a few of them and make it a maintenance item every year.
