Steering Lock
Discussion in 'Technical Chat' started by KixRock, Jan 16, 2018.
  1. Jan 16, 2018 at 6:24 PM
    KixRock
    KixRock [OP] Member
    Kix
    2009 Tacoma Double cab V6
    I have a 2009 Taco Pre Runner 2 WD gthag I am setting up to flat tow. Can someone please tell me how to keep the steering wheel unlocked while I am towing the Taco? TIA
  2. Jan 16, 2018 at 6:31 PM
    Bishop84
    Bishop84 Well-Known Member
    simply leave a key in the ignition after turning it. Not ideal.
    I do not believe the transmission is designed to have the output shaft turn without the front shaft turning, this leads to the output starving for oil.
    Most people flat tow little 4x4 like samurais or jeep's due to the "true transfercase neutral" with oil pump on the output shaft.
  3. Jan 16, 2018 at 6:51 PM
    KixRock
    KixRock [OP] Member
    Kix
    Bishop84 Thanks for the reply. Leaving the key in the ignition may be my best option but I hope not.
    I am installing a driveshaft disconnect which will prevent the output shaft from turning. Over the years I have towed many Jeeps without problems. The Jeep transfer case has a true neutral position. My Taco is a 2WD with AT and that's the reason for the d/s disco
