steering makes groaning sound when turning
Discussion in '1st Gen. Tacomas (1995-2004)' started by danielsan, Dec 23, 2011.
  1. Dec 23, 2011 at 2:07 PM
    danielsan
    danielsan [OP] Member
    daniel
    asheville nc
    95 4wd 2.7L
    when i turn the steering wheel when idle or at lower speeds i get this groaning sort of sound.
    what would it be?
  2. Dec 23, 2011 at 2:08 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Check your power steering fluid?
  3. Dec 23, 2011 at 2:08 PM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    Lack of power steering fluid, check the reservoir.
  4. Dec 23, 2011 at 2:10 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    ^^^Check your fluid.
  5. Dec 23, 2011 at 2:17 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    and if your fluid is low, you most likey have a leak. Ps fluid doesn't just go low on it's own.
  6. Jan 13, 2012 at 9:59 AM
    danielsan
    daniel
    asheville nc
    95 4wd 2.7L
    yup it must be a leak...
  7. Jan 13, 2012 at 12:40 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    There is also a screen at the bottom of the reservoir that gets dirty and plugged causing noise. (basically causes low PS fluid symptoms even if it isnt low) I sucked the reservoir empty and shop vacuumed the screen clean and havent had a problem since.
    Some guys just jam a screwdriver through it and it fixes the problem too. Most vehicles dont have the screen there anyway
