steering noise problem,
Discussion in '1st Gen. Tacomas (1995-2004)' started by Joshmercs, Mar 21, 2023.
  1. Mar 21, 2023 at 12:09 AM
    Joshmercs
    Joshmercs [OP] New Member
    joshua
    1999 Toyota Tacoma limited 4x4
    none
    Hello everyone, I own a 1999 toyota tacoma limited 4x4. I had a loud squeaking noise everytime I would turn. so I changed the powersteering pump thinking it was that. and the noise left for a little and its back now. not as loud but its back. another not is that when it rains the noise goes completely away. do I replace the front suspension or do I look towards the rack and pinion. Any information would help. Thank you!
  2. Mar 21, 2023 at 10:42 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Before you throw more parts at it, you need to identify what is making the noise. Does it make the noise when you are stopped and turn the wheel? If so, have a friend turn the wheel while you try to pinpoint the source of the noise. You may need an automotive stethoscope. They are really cheap (especially at Harbor Freight) and go A LONG way in helping to determine where a noise is coming from.
    I had a rotational squeak that would come and go with differences in humidity. I changed so many things in pursuit of that squeak. It ended up being my front wheel bearings, even though they showed no other sign of failure.
    You need to do some more work before you throw parts at it.
  3. Mar 21, 2023 at 4:18 PM
    Joshmercs
    joshua
    none
    Yea it does make the noise even at stand still. And ok ima go to harbor freight.
  4. Mar 21, 2023 at 4:22 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Did you clean the screen in the reservoir? It gets missed a lot and doesn’t get replaced wit the pump if I remember right. It causes noise when it clogs up and starves the pump.
    Abeyancer likes this.
  5. Mar 22, 2023 at 12:46 AM
    Joshmercs
    joshua
    none
    Yes I did clean it out
  6. Mar 22, 2023 at 7:52 AM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Have you ruled out steering rack bushings? The U-shaped one underneath the U-bracket on the passenger side of the steering rack squeaks on my truck from time to time. A little white lithium grease applied liberally usually shuts it up for a while. As others have stated, you gotta get down there and watch and listen while the noise is being replicated by someone else turning the wheel.
