Steering Play after Tire Replacement - Michelin MS/2 LTX > Cooper Discovery ATX
Discussion in 'Wheels & Tires' started by cpyne, May 20, 2023.
  1. May 20, 2023 at 11:02 AM
    cpyne
    cpyne [OP] Member
    Ashland, MA
    2014 Tacoma Double Cab TRD Off Road
    2014 Double Cab OR, Stock. Recently replaced my tires, Michelin MS/2 LTXs replaced with Cooper Discovery ATXs. Now I have much more play in the steering. On the highway, I'm constantly trying to keep it balanced in the center of the lane. I had the tire shop do an alignment and recheck and they said it all looked fine.
    Is this normal with a switch from LTX to ATX? Considering bailing on these Coopers and going back to Michelin if that will solve this.
  2. May 20, 2023 at 11:06 AM
    MGMDesertTaco
    They probably did a poor job on balancing them or you have some worn suspension components. Likely the first.
    cpyne[OP] and Wulf like this.
  3. May 20, 2023 at 11:09 AM
    Admiral Snackbar
    Admiral Snackbar Well-Known Member
    Its also possible that its the mold release compound on the new tires. It'll take a few hundred miles for that to wear off. Also consider you have much more tread depth now, instead of shallower worn old tires
    cpyne[OP] likes this.
