Steering pop at low speeds
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drewbert41, Dec 16, 2018.
  1. Jan 19, 2019 at 1:41 PM
    drewbert41
    drewbert41 [OP] Well-Known Member
    Champaign, IL
    21 Cement DCSB 4x4 TRD OR
    They are replacing the steering rack for free. Said its shot.
    jross20 likes this.
  2. Jan 19, 2019 at 5:28 PM
    devkurf
    devkurf Member at Large
    midwest
    did you buy an extended warranty?
  3. Jan 23, 2019 at 12:25 PM
    drewbert41
    Champaign, IL
    No
  4. Jan 23, 2019 at 12:33 PM
    drewbert41
    Champaign, IL
    From my paperwork:
    Found the cause of the noise to be coming from the steering rack. Found that the mounts were extremely worn and there was noise coming from the gear as well. Also found tie rod ends loose.
    Installed: Tie Rod End
    Installed: Reman Rack Pinion
    Installed: Brake Fluid
    Replaced Steering Rack and Tie Rod Ends.
    Alignment completed.
    Truck rides and turns smoothly now.
    deanosaurus and HillJackJDS like this.
  5. Jan 23, 2019 at 1:11 PM
    devkurf
    midwest
    Your truck is an 05? Did you just buy it? I'm curious how you got the dealer to pay for it.
  6. Jan 23, 2019 at 1:23 PM
    drewbert41
    Champaign, IL
    Just bought it.
  7. Jan 23, 2019 at 1:28 PM
    devkurf
    midwest
    ok, makes sense then
    TnShooter likes this.
  8. Jan 24, 2019 at 6:06 AM
    96carboard
    96carboard Well-Known Member
    Probably a bad CV joint on the front. Doesn't have to be in 4wd -- they turn with the wheels.
  9. Jan 24, 2019 at 7:40 AM
    drewbert41
    Champaign, IL
    I posted the fix already.
  10. Dec 18, 2019 at 9:38 AM
    drewbert41
    Champaign, IL
    Popping again when turning left into parking spaces.
  11. Aug 23, 2022 at 8:34 PM
    TacoTuesday1
    SD CA
    bump for anyone else who has gone through this and learned the fix
    currently experiencing an intermittent but frequent pop/knock from what appears to be the steering. Happens when turning and over bumps
    Already replaced so much trying to resolve it:
    -LCA's
    -UCA's
    -rack bushings (poly)
    -inner tie rods
    -outer tie rods
    -deleted swaybar/endlinks
    -spindles
    -shocks (6112, clip 4 both sides)
    -KYB strut top hats
    -LCA mounting tabs are upgraded
    They say to grease the steering stops, and I will, but I don't think that has much to do with it given they're there for full lock.
    Seems like the only thing left that can be bad is the rack (which is currently slowly leaking black fluid from the boots), and column system parts connecting to the steering wheel
  12. Aug 23, 2022 at 9:42 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Are the LCA cams torqued to 100 lb/ft?
    It's easy to come up short if your just tightening by hand with a big wrench
  13. Aug 26, 2022 at 9:14 PM
    007fodo
    007fodo Gold Member
    Ian
    Coastal North Central CA
    4X4 V6 5AT DCSB 07
    Have you checked your 4wd system? Axles, front driveshaft, bushings
  14. Aug 26, 2022 at 11:13 PM
    TacoTuesday1
    SD CA
    1.probably not
    2.exactly what I did
    Thank you, I'll check. Hopefully it's still where I left it doing the alignment.
    I'll check the repair manual to verify torque spec. That sounds pretty high given that lug bolts are 86-87 ft lbs.
    Just going off experience aligning passenger cars that don't get 100 ft lb
    Don't know if that would cause a noise (may perhaps lose/move alignment) but I know I definitely didn't tighten them to 100 ft lb
    Think I found it though. Steering rack bolts were not fully torqued. After tightening them some, pop noise has decreased or gone away
    Came 6mo if not more after installing poly rack bushings. They probably had some give/settled and shrunk down over time losing tension on the bolt.Or are harder to squish and get tight vs OEM rubber
    Not sure how any of that would be a problem.
    CV boots are intact, bushings are new. Not sure what would wear on the front propshaft; that likely does not spin in 2HI. Greased the slipyoke fitting wherever that is, under a year ago.
    Pop was at low speed steering, not high speed constant rotational.
  15. May 28, 2024 at 3:23 PM
    #35
    Thefinalfight
    Thefinalfight Born for the road
    Calvin
    Pittsburgh pa
    2013 Tacoma trd 4x4 v6 4.0
    Brake controller (aftermarket) Receiver hitch
    Hey brother sorry to revive an old thread wondering if you ever sorted this out the second time? Couple months ago my steering got really loose started making a pop and my mechanic replaced the rack and pinion along with the bushings. Got my truck back and made zero difference in the steering. I had to keep driving for work and eventually I got used to it or it started to feel a little bit Better. Recently I started that again that you're talking about even after the rack was replaced I'm thinking it might lower control my ball joint and I have the parts ready to go in I'm Just trying to get some insight before I dig too deep
  16. Aug 27, 2024 at 3:29 PM
    #36
    Thefinalfight
    Calvin
    Pittsburgh pa
    Yes it is
