Steering Problems Offroad
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Notserp, May 23, 2017.
  1. May 23, 2017 at 9:12 AM
    Notserp
    Notserp [OP] Active Member
    Preston
    2015 TRD OR DCSB
    Folks,
    Would you all be able to share input on how much your steering wheel is forced left or right when driving offroad and hitting uneven terrain at slow speeds? Do you have OEM wheels or higher offset?
    Here is my situation. Stock suspension SCS Stealth 6 17" wheels with KO2's 265/70 R17 Load C. Vehicle is aligned.
    So I went on a varmint hunt and drove around farm fields for a weekend at very slow speeds 5-10mph max. When going over the uneven terrain my steering wheel would whip pretty dang hard left or right about 1/4 turn. It was annoying as hell. I knew the offset of the new wheels would have an effect, but I didn't think it would be that drastic.
    When driving on gravel logging roads my steering wheel also vibrates a lot just from the gravel. Also annoying as hell. 16K miles on the truck.
    Appreciate the input.
    Preston
  2. May 23, 2017 at 1:56 PM
    Notserp
    Preston
    2015 TRD OR DCSB
    Maybe I posted in the wrong place. bump for input. :fingerscrossed:
  3. May 24, 2017 at 10:51 AM
    Notserp
    Preston
    2015 TRD OR DCSB
  4. May 24, 2017 at 11:38 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    have a steering stabilizer?
  5. May 24, 2017 at 11:40 AM
    Notserp
    Preston
    2015 TRD OR DCSB
    No. Truck is mostly stock. Will read up on what that is. I haven't seen many Tacoma folks talking about them though.
  6. May 24, 2017 at 12:36 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    No worse than my previous truck and nothing that isn't prevented by holding the steering wheel.
    Notserp[OP] likes this.
  7. May 24, 2017 at 12:42 PM
    youcantseeme
    youcantseeme Well-Known Member
    E
    Colorado
    2015 SSM Taco TRD
    13 cupholders for beer. All the Weathertechs.
    Are you driving without your hands on the wheel? The only time I ever have this "problem" is when I'm being a jackass 4-wheeling, and am going 20mph+ over rocky terrain and I catch a wheel on a large rock.
  8. May 24, 2017 at 12:47 PM
    Fish12South
    Fish12South Well-Known Member
    Steven
    Ruther Glen, VA
    2008 Indigo Ink AC SR5 6 Speed V6
    Not Enough.
    I'm also going to assume you (OP) weren't holding the steering wheel. I think the easiest solution to fix your steering, is by actually steering it.
  9. May 24, 2017 at 1:10 PM
    Notserp
    Preston
    2015 TRD OR DCSB
    Ha! You guys are hilarious. Yes I'm holding the wheel. While holding the wheel hitting the bumps in the farm fields whips the wheel and jars my hands back and forth. Driving down a gravel road at 20mph vibrates the steering the wheel and shakes my arm. I should take a video of it. I will do that next time I'm on gravel or uneven terrain.
    I did get the truck aligned again today. Alignment was close. For some reason i had negative toe in the front, which has been corrected. Drives better on the road, but I haven't had it off road yet.
    stickyTaco likes this.
  10. May 24, 2017 at 1:19 PM
    Fish12South
    Steven
    Ruther Glen, VA
    Not Enough.
    Sometimes you just gotta cover all the bases. :rofl:
  11. May 24, 2017 at 5:26 PM
    tacoma4
    tacoma4 Well-Known Member
    Mine does the same. Up and down the gravel road and I feel every rock and bump through the wheel. The 99 4runner is smooth as butter. Both stock wheels.
  12. May 25, 2017 at 6:01 AM
    5678ta
    5678ta Well-Known Member
    Hogan
    Henderson, NV
    '18 ECLB Colorado ZR2
    Though this is not uncommon, it's caused by Caster adjustment. Too little with make steering twitchy. Try having alignment shop add a degree of positive caster.
  13. May 25, 2017 at 8:02 AM
    Notserp
    Preston
    2015 TRD OR DCSB
    Well that's a bummer to hear, but I'm glad I'm not the only experiencing it. Thanks for sharing your experience.
