Steering pulls when applying brakes
Discussion in '1st Gen. Tacomas (1995-2004)' started by 01stgentaco, Aug 20, 2025.
  1. Aug 20, 2025 at 6:07 AM
    01stgentaco
    01stgentaco [OP] Deacon
    Deacon
    Hello,
    I recently replaced the sway bar links on my 2001 toyota tacoma. I drove it around for about 2 days afterwards and everything felt smooth. Yesterday I was driving and hit a little bump in the road which caused my front end to dip and my tire began to screech. Sway bar links seem to be intact but when applying the brakes the steering wants to cut right. additionally now whenever hitting anything in the road like a manhole cover it sounds like metal banging coming from the front driver side wheel.
    Any tips or suggestions are gratefully appreciated
  2. Aug 20, 2025 at 6:16 AM
    02hilux
    Planet: EARTH
    Hate to say it but could be anything from worn out suspension, bushings, to LCA.
    Had a front wheel bearing go out and will only make “metal to metal” noise when the tire bounce.
    01stgentaco[OP] likes this.
  3. Aug 20, 2025 at 6:19 AM
    t0p_d0g
    t0p_d0g My Tacoma is my happy place
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Typically when applying brakes if it pulls to the right it would be an issue with the right side front brakes.
  4. Aug 20, 2025 at 4:32 PM
    01stgentaco
    Deacon
    Took off both tires and found that my driver side rotor broke, Replaced both rotors but when I bolt up the caliper on the passenger side the bolts dont wanna line up and when they do and you get the screws in the caliper will no longer freely spin. Brake pads are new and caliper was squeezed down so that inside is flat when reinstalling. Im guessing wheel bearings but before i take it to a shop due to them being pressed in on my tacoma, is there anything else i should try?
  5. Aug 20, 2025 at 4:44 PM
    t0p_d0g
    That’s why your brakes were pulling to the right no brake on left side cause broken rotor.
    These trucks have two size diameter rotors. Are you sure you have the correct diameter for your truck?
  6. Aug 20, 2025 at 6:10 PM
    01stgentaco
    Deacon
    i believe so, only the passenger side rotor is locking up now when the caliper is reinstalled but driver side moves fine.
  7. Aug 20, 2025 at 6:14 PM
    t0p_d0g
    Check your boxes make sure you have the same part number. You may have the correct for the left and the larger diameter for the right.
  8. Aug 20, 2025 at 6:22 PM
    t0p_d0g
    It might be a good idea to pull the right side rotor off and compare it to the one you removed. While you are at it just double check how the caliper is mounted.
