steering pump
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Barry J, Apr 3, 2014.
  1. Apr 3, 2014 at 5:57 PM
    Barry J
    Barry J [OP] Well-Known Member
    Massachusetts
    What symptoms tells me my power steering pump is going??
    Right now the past two days, the steering is getting stiff, and seems to get worse the more I drive it.
    I topped off the fluid, but does not seem to fix problem
    I'll spray lube the shaft joint tomorrow to see if it makes a difference.
    But how to I check the pump???
    There does seems to be a slight noise under the hood, ticking
    Thanks
    Barry
  2. Apr 3, 2014 at 6:55 PM
    Barry J
    Massachusetts
    And what should I use to spray the steering joint
  3. Apr 4, 2014 at 5:12 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Any penetrating lube will do - moovit, pb blaster, even fluid film, and if the steering feel improves, replace the lower steering shaft assembly.
    The only conclusive way to test the pump is with a flow meter, and I'm assuming you do don't have one of them laying around either. I'd concentrate on that u-joint to begin with.
  4. Apr 4, 2014 at 5:27 AM
    LowerBost
    LowerBost Well-Known Member
    Nick
    Pittsburgh, PA
    09 Tacoma Sport
    Old Man Emu Lift w/ Dakars and Billsteins, K&N Intake, Throttle Body Space, Front Bull Bar, Side Rails, Painted Stock Rims, Bilstein 5100 Front Shocks, Third Brake Light Cover, Satoshi Grill Mod, BHLM Mod
    I used a spray from PB Blaster that's supposed to be used for garage door lubricant. Its a silicone film. Sprayed the joint and it was fine....for a week...sprayed it again....we'll see if it make it through the weekend. Lower joint needs replaced sooner rather than later on mine. But as for the steering, it gets real stiff and kind of goes loose and stiff as I go around turns.
