Steering rack bolt help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nastyneight, Jul 27, 2015.
  1. Jul 27, 2015 at 2:06 PM
    nastyneight
    nastyneight [OP] Well-Known Member
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    Having a heck of a time finding a bolt for my steering rack. Started last month I replaced my bushings with energy suspension bushings. I did the cut the bolt instead of move AC compressor. I had preorderd bolt from Toyota using part number from another thread on the forum. The bolt was a good inch to short. I used a bolt I had to get by (but want a OEM bolt). I figured that maybe mis package or something, so I went back to toyota and me and parts guy confirmed the part number, and reordered, with same issue to short. When I found out first was to short I did compare to the stock one I was reusing and they were different. So question is am I a idiot and missing something, or anything?
  2. Jul 27, 2015 at 6:35 PM
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
    I too will be replacing my rack bushings with Energy Suspension parts. How difficult was it for you? Not looking forward to laying on back for hours. Have read many threads on proper procedures and pretty much am ready to jump in soon.
    When you figure out the correct part number for the bolt please post it for all. Also did you have to replace the power steering seals? If you did do you have the part #'s
  3. Jul 27, 2015 at 6:39 PM
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    I did not have to replace any seals, Mine was part of a whole front end redo, I had axles, diff, Lower arms all off to do work. I hope someone will chime in about the bolt issue
  4. Jul 24, 2016 at 1:18 AM
    njcoma
    njcoma Well-Known Member
    California
    2017 Accord Sport Special Edition
    Previous: 2006 Tacoma SR5 Prerunner: 2010 4Runner sr5 Rims, TSB rear leafs, Wetokole neoprene seat covers, JVC LED color matched head unit, scanguage II, Flowmaster 40 cat back exhaust, hankook dynapro atm tires, Class 4 Uhaul Hitch. Kicker 12 inch sub and amp. Focal speakers. jba offroad UCAs.. Detroit truetrac rear end... bilstein 5100 rear and 6125 front coilovers. Nfab front bumper with KC apollo lights, bed lights, bluesea systems fuse box....lots of painted stuff.
    Anyone ever find that part number?
  5. Jun 25, 2018 at 7:31 PM
    Goon
    Goon New Member
    For anyone lucky enough to land here...
    Regarding the 2nd generation's steering rack mounting bolts:
    The longer bolt has Toyota P/N 90119-A0135 and an overall length of about 167mm.
    The shorter bolt has P/N 90119-A0137 and an overall length of about 141mm.
    Both bolts have the same diameter, washer, and threaded length.
    Rat_Bastard and nastyneight[OP] like this.
  6. May 17, 2019 at 8:57 AM
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    Just ordered on for myself and my parts guy told me the below information
    4wd - Toyota P/N 90119-A0135
    2wd - Toyota P/N 90119-A0137
  7. Nov 28, 2022 at 7:47 PM
    Tacomasprime05
    Tacomasprime05 Well-Known Member
    Evan
    Charlotte
    Blue trd sport 05
    Led light conversion Kn air filter Total chaos uca King coilovers Cab mount chop Headlight hydrodip housing Grill craft/ Bay Area metal fab grill Light bar in hood scoop Weld on spindle gusset SOS concepts sliders Soft topper Bluetooth radio conversion
    Bit of a thread revival, but went through this today. Cut the driver side bolt out instead of lifting motor. Hence needing to replace it. That being said aforementioned part numbers are correct. And length of bolt is correct. The bolt is a m12x1.25.
    Hope that helps any1 sourcing outside of the dealership.
    As a side note since I wheel pretty hard, I ended up placing a 1 1/2” round washer on the bottom side of the frame cross member mounting locations to help distribute stress on mounting sleeve. Especially since it’s only welded on 1 side.
    Naveronski likes this.
