Steering Rack Boot Movement - Advice/Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Madjik_Man, Jul 25, 2020.
  1. Jul 25, 2020 at 9:42 AM
    Madjik_Man
    Madjik_Man [OP] The Rembrandt of Rattle Can
    Colorado Front Range
    2004 Tacoma
    Looking at replacing my LBJs here soon. Was under the truck prepping the bolts with PB Blaster and noticed there was fluid on the steering rack boot on the driver's side. All the the most inboard end.
    I wiped it clean and wanted to test out to see if any steering fluid was noticeably coming out when the rack was moving.
    1. There's a friggen zip tie holding the boot in place. And it's not cinched down tight enough to prevent the boot from moving. Watch the very end of the first video, specifically the bottom of the zip tie. You can see that lip of the boot move. It does it in both directions.
    2. The passenger side boot was clean, no fluid. It too has a fuggen zip tie holding the boot but it moves even more than the driver's side.
    3. No rips or cracks in the fins or boots that I can see.
    My question: Is this a major issue? The boots obviously do not come off the rack so are they still doing their job of keeping crud out? Anywhere else I can check to see if there is a steering rack issue? (I have the steel clamps on order and should have them on Tuesday)
    I'm hoping the fluid I cleaned off was just spilt oil from an oil filter change (had it done at a shop so who knows how careful they were/n't?).
    I guess I'll drive around for a bit and keep checking that one area for more fluid.
    Driver's Side:
    https://www.youtube.com/watch?v=UqHjpTzkObs
    Passenger's Side:
    https://www.youtube.com/watch?v=xkR5CtiPqoM
    Thanks for any advice/help
    GQ7227 likes this.
  2. Jul 25, 2020 at 1:28 PM
    BrianTaco75
    BrianTaco75 Well-Known Member
    Brian
    1995 Taco / 2019 Taco
    yeah zip ties are really pitiful how long have they been like that? If they are holding you are ok, i guess. I would run down and the thin clamps that you screw to tighten. on the oil was it red?, more like transmission colored? if so then sounds like you have a leak. Sorry I'm not much of any help
  3. Jul 25, 2020 at 1:40 PM
    Madjik_Man
    No worries.
    No idea how long they’ve been like that. Bought the truck in August.
    The rack is reman’d so it was replaced at one point. Based on the look of the zip ties they look fairly new. Not weathered or beat up at all. So hopefully not too long.
    No red tint to the fluid/funk at all. Black. Makes me believe it’s oil from a sloppy oil filter change.
    But wouldn’t power steering fluid leak from the rack? That doesn’t have a red tint does it?
    Or am I completely off entirely?:)
  4. Jul 25, 2020 at 2:04 PM
    BrianTaco75
    Brian
    our racks use dexron atf which is red so if it's black and you can actual look in the light/sun and see no red ting to it I believe like you said oil then and not the rack
    Madjik_Man[OP] likes this.
  5. Jul 25, 2020 at 2:04 PM
    BrianTaco75
    Brian
    sorry our powersteering system uses dexron atf
  6. Jul 25, 2020 at 2:06 PM
    BrianTaco75
    Brian
    i think it specifies on the power steering housing cap
  7. Jul 25, 2020 at 2:08 PM
    BrianTaco75
    Brian
    if the seals are shot on the rack yes it can leak. You said it was recently replaced then it should be good.
  8. Jul 25, 2020 at 2:10 PM
    Madjik_Man
    Im just guessing that it was recently replaced based on the condition of the “reman” sticker and zip ties.
    Used a clean white rag. Not a hint of red in the grime/fluid.
    Thanks for all the info. Appreciate it.
  9. Jul 25, 2020 at 3:27 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If you have those boots completely dry your doing good.
    How many quarts of ATF do you add for 100 miles of driving
    Those cable ties mean the boots were removed for some reason and the original clamps were lost and it was to much time to get them from the Local dealer
  10. Jul 25, 2020 at 7:22 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    Mine are wet like that but not leaking. Been like that since I bought it in 2011. I think it’s from messy oil changes. Also I wouldn’t worry about the zip ties too much. When I changed my tie rods I used large zip ties as well. I believe that boot should fit into a groove though. Mine don’t move like that. Might want to replace with new and get a cable tie tensioner to get them nice and snug.
  11. Jul 25, 2020 at 7:38 PM
    Madjik_Man
    When I get the OEM steel clamps on there I’ll try to reposition them appropriately. I could see/feel a groove on the rack.
    ffirg[QUOTED] likes this.
