Steering rack bushing suggestions
Discussion in '1st Gen. Tacomas (1995-2004)' started by El Taco Diablo, Dec 12, 2017.
  1. Dec 12, 2017 at 9:56 PM
    El Taco Diablo
    El Taco Diablo [OP] Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    So, this kind of goes along with my tie rod end replacement post.
    I replaced these bushing on the steering rack at the same time I replaced all my tie rod ends. (https://www.tacomaworld.com/threads/tie-rod-end-replacement-suggestions.523928/)
    Steering rack part number:
    Energy Suspension Polyurethane
    8.10103G
    Before I started, I found this video was most helpful in familiarizing myself with what I would be doing and the tools that would be needed.
    https://youtu.be/iQ7i7QVx-lA
    The guy in the video pretty well covers it. But I figured I would share some additional info I learned while I was doing mine. EXCEPT the grease he uses. See note at the bottom of this post.
    Here is a picture, for refernce. The picture is facing the front of the truck, taken from under the truck behind the steering rack.
    First of all. Your oil filter is located above #1 and #2 in the picture. Why is this important? If you have ever spilled oil out of your filter, while changing it, I would suggest you check and make sure you clean that off the top of the #2 bushing (#2 bolt and bushing are vertical). If oil sits on top of this bushing, it will rot it. The #2 bushing on mine was about 30% gone. When I started pulling the bolt, oil started seeping out like it was a plug. (This exessive amount of oil was due to the fact that I got lazy and had the oil changed by a quick lube and they left the new filter loose... but I would still definately suggest checking).
    My #1 bushing was in, by far, the worst shape. It was probably over 50% gone. It was easy to see it was in bad shape. The rubber was bulging out between the washer.
    As I said above, I did this replacement while doing the tie rods. I would recommend this, as I think it made the process easier. But as you can tell in the video, it is possible to do without removing the tie rods, or disconnecting them. I would definately recommend inspection of the steering rack boots for holes etc at a minimum... and would also recommend moving the boots to inspect the inner tie rod.
    I removed the sway bar, to make things easier, as well. (This is where I kicked myself in the ass for not having already ordered a new sway bar bushing kit... do that, if you are replacing the rack bushings!) Removal of the sway bar allowed more room between the steering rack and the crossmember.
    The #1 bushing can only press out one way, and that is towards the crossmember the rack is mounted to. I used an old 14mm socket and big f'n hammer to pound out #1. I placed the head of a 1 1/2 pound dead blow hammer between the rack and the crossmember to support things while I pounded on it. (a piece of 2x4 would probably work too) I used an "F clamp" to press the new #1 back in. The "F clamp" kept the bushing from pressing out the back when I pressed the sleeve into the bushing.
    The #2 bushing pounded out (up) relatively easy for me. I used the "F clamp" on this one too, to push it back in.
    The #3 bushing is just a straightforward U bracket.
    Note: before you start putting the bushings back in, need to thoroughly clean the areas they go in. I used super clean, dried it completely with a rag and then used 200 grit sand paper strips to get all of the hard residue and any pits smooth.
    Energy Suspension does not mention greasing these bushings. Some people don't grease them. I greased mine with Super Lube.
    **Do not use ANY kind of petrolium based grease on Polyurethane. Petrolium based lubes will eat polyurethane. Super Lube is non-petrolium based. Lithium grease is non-petrolium as well.**
    1997TacomaSR5, uurx and TrentonTDG like this.
  2. Dec 13, 2017 at 8:15 AM
    Glamisman
    Glamisman Well-Known Member
    were there any symptoms or did you do this because you were in there anyway?
  3. Dec 13, 2017 at 8:49 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    The main symptom was that when ever I hit a bump the truck would get all wild on me. The steering also felt pretty loose in general.
    I wasn't sure if it was the rack bushings or the tie rods, so I decided going in I would replace both while I was in there.
    Comparing the wear I found on the tie rods and the wear on the rack bushings... I am pretty sure most of the loose steering was from the rack bushings.
    The brake shimmy I was feeling, and the uneven tire wear, was probably the tie rods.
  4. Feb 12, 2018 at 11:49 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    @Uphillshunter
    Did you notice any clunking/popping when turning your steering wheel when your bushings were bad?
    I'm chasing a really bad pop/clunk noise when turning (and sometimes when going straight)...I've ruled out the sway bar, ball joints, CV axles, wheel bearings, etc. Thinking it must be the bushings in the steering rack (hopefully).
    Thanks for the write up/video, this will help me out a ton when I do them later this week.
  5. Feb 12, 2018 at 7:00 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I never had a clunk when I was having problems wit h my rack... but your bushing may be more done than mine were.
    Have you checked the bushings on your upper and lower shock mounts? (and if they are tight) Those could give you a clunk when turning (and going straight for that matter).
    TrentonTDG likes this.
  6. Feb 12, 2018 at 8:55 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Not sure if any of your questions could be answered here:
    @eon_blue have you checked your LCA cam bolts? I had a repetitive pop when one of those was stripped even though everything was torqued to spec. Other people have gotten clunks / pops when their LCA bushings wear out and create play. I jury rigged an iPod to video where the sound was coming from to pin point it. Some guys suggested a cheap GoPro knockoff would make that easier - I think they were correct lol.
    1997TacomaSR5 and eon_blue like this.
  7. Feb 12, 2018 at 9:17 PM
    eon_blue
    Azusa, CA
    I haven't looked too hard at those, but I think I should...I've had an alignment done twice now and the popping has still been the same so I didn't really consider it could be the LCA bolts, but I'll check them.
    I ordered the same Energy Suspension kit that @Uphillshunter installed for my steering rack, the bushings look OK from what I can see behind the skid plate but I can't see much. I know a buddy of mine with a 2nd gen had bad steering rack bushings and his truck sounded like popcorn when he turned the wheel haha, which is why I was thinking that might be the culprit.
    I was convinced for a few weeks that it was my CV axles, because the angles were really bad but even after the diff drop and replacing the CVs, the popping hasn't gone away. I even lowered the Kings down about a half inch (angles look much better now). So I've about 90% ruled out that as being the issue, unless I got unlucky with the used CV axles that I put in (which would suck).
    In any case, it couldn't hurt to replace the bushings just to have upgraded ones and rule it out...the kit was only $25. I'll try to install it this week and report back.
  8. Oct 25, 2019 at 12:43 PM
    Phessor
    Phessor Well-Known Member
    Bob
    1998 TRD XTra Cab
    Stuff
    I know this is an older thread, but when I went to replace my bushings I could not get the center bolt to come out. It hit the oil pan!
    All the videos I have watched do not address this issue. Am I doing something wrong?
    How did you get yours out and in?
  9. Oct 25, 2019 at 12:45 PM
    eon_blue
    Azusa, CA
    Interesting, I had the same problem but not hitting the oil pan...mine hits the front differential (just barely). Are you sure it's the oil pan?
    The reason it hits the front diff on my truck is because of the useless diff drop I installed...either have to remove the diff drop (what I plan on doing) or shave down the flange on the head of the long bolt so it clears the diff.
    In my case, that flange on the bolt head is all that hits the diff, but it's enough to prevent the bolt from coming out completely.
  10. Oct 25, 2019 at 1:02 PM
    Phessor
    Bob
    1998 TRD XTra Cab
    Stuff
    You are correct, it hits the front differential when I tried to pull it up.
    eon_blue[QUOTED] likes this.
  11. Oct 25, 2019 at 1:04 PM
    eon_blue
    Azusa, CA
    Have a diff drop installed? Easiest thing to do would be to remove it and put it back on when you're done with the bushings
  12. Oct 25, 2019 at 1:10 PM
    Phessor
    Bob
    1998 TRD XTra Cab
    Stuff
    I do, and I will see if it works for me, thank you.
  13. Jun 7, 2023 at 7:42 AM
    roary_tubbs
    roary_tubbs Active Member
    Oklahoma City, OK
    2011 White Toyota Tacoma TRD
    After replacing the busing with polyurethane has anyone had issues? I put mine on along with a new assembly about 15k miles ago and I just had to tighten the 2 bolts that go up through the bushings. They had become extremely lose, so much that when I'd go over bumps it throw my steering wheel from 12 to 2 while still driving straight.
  14. Jun 7, 2023 at 7:53 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I've had my steering rack bolts come loose on me as well. And I have also broken the welded nut and bolt on the passenger side. I made the necessary fixes to the nut and bolt on the passenger side and run red locktite on all the rack bolts.
    I don't think this is a problem that is due to poly bushings though.
  15. Jun 7, 2023 at 10:30 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    I dunno, but I think that poly bushings are just as hard and non-giving as solid steel bushings. And I've tried them before, so I'm just gonna keep using Toyota rubber bushings in my steering and suspension.
    JustADriver and 1997TacomaSR5 like this.
  16. Jun 7, 2023 at 5:58 PM
    1997TacomaSR5
    1997TacomaSR5 OG TACO - 3ook+ ...where 2 wheel next
    It appears that 2 of the 3 rack bushings are not separate from the rack as standalone replaceable items
    How would one best deal with that?
  17. Jun 7, 2023 at 6:20 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    They are all 3 replaceable, this diagram just shows that new Toyota racks come with them preinstalled.
  18. Jun 7, 2023 at 6:22 PM
    1997TacomaSR5
    I do not see OEM part #s on that diagram
    Where can you find the Toyota part # to order from online discount yota dealer
    I thought every replaceable part are listed on those :notsure:
  19. Jun 7, 2023 at 6:37 PM
    Red_03Taco
    Jerad
    I believe that Toyota doesn't sell them separate from a new rack. Therefore just about everybody goes with aftermarket poly bushing options.
  20. Jun 7, 2023 at 8:53 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    The Poly Bushings are just better than the rubber bushings. I wouldn't even consider OEM rack bushings at this point.
    Some people say they've had bad luck with Energy bushings. I didn't. Mine lasted until I broke the 2 passenger mounting bolts on the passenger side about 15 miles in to a 31 mile trail. By the time I got home, they were toast. (nothing to do with the bushings themselves.)
    I did try Whiteline now... they are good as well.
    And lots of people are using the @TOTAL CHAOS rack bushings, and like them.
