Steering rack bushing suggestions
Discussion in '1st Gen. Tacomas (1995-2004)' started by El Taco Diablo, Dec 12, 2017.
  1. Jun 7, 2023 at 9:09 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I've been wondering if a harder material like delrin or even SS might be the way to go. Since a lot of rack failures result from the 2 part case flexing or even breaking, it might be similar to a similar problem with light full size Chevy racks that a lot of prerunner guys break due to a similar 2 part cast case.
    A local fabricator specializes in Chevy and has a pretty built shop truck with a stock rack that he said he has never broken a rack with once he put these bushings and billet clamp mount on.
    https://www.izzyfab.com/product-page/07-13-gm-1500-billet-steering-mount-kit
    I don't think he's making it up.
    https://www.youtube.com/watch?v=YD8brrqm9G8
    A small company started making billet passenger side clamps for 1st gen / 3rd gen t4r's stating that that stamped collar will flex too much allowing the case to pivot and flex and crack too. I probably won't be buying their part, but am thinking about welding / boxing in the stock one.
    https://333fabrications.com/products/hd-billet-rack-clamp
    The difference between this and IzzyFab's is his solid mounts the clamp to the rack with pinch bolts rather than a bushing.
  2. Jun 7, 2023 at 9:26 PM
    El Taco Diablo
    El Taco Diablo [OP] Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I have been considering getting the 333 clamp since I saw, I think it was @1997tacomav6, post it.
    I will be ordering it soon.
    1997TacomaSR5 and 1997tacomav6 like this.
  3. Sep 15, 2024 at 2:39 PM
    roary_tubbs
    roary_tubbs Active Member
    Oklahoma City, OK
    2011 White Toyota Tacoma TRD
    I'm still having issues and wondering if it's the polly bushings or something else. I was out on a trail the other day and when I came down it moved the positioning of my steering. I ended up pulling up to a rock and turning my steering wheel into the rock to straighten it out a bit. I don't feel like it's the bushings, any idea what this could be or areas I should start looking?
  4. Sep 15, 2024 at 9:51 PM
    DoktorSlowburn
    DoktorSlowburn Well-Known Member
    Escondido, CA
    1997 White Tacoma SR5
    4runner seats and center console, ARB rear locker, Icon 1.5” AAL, Bilstein 5100 on 4th notch in front (to support future tube bumper & future winch), 4600s in the rear. In-Cab CB radio. Hella 500 Driving lights. All-Pro Baja front bumper.
    I’m still new to trucks, so take this with a grain of salt. But to me it sounds like your rack & pinion may be shot
  5. Sep 17, 2024 at 9:44 AM
    roary_tubbs
    Oklahoma City, OK
    I replaced both front sway-bar links, outer tie rods, front sway bar bushings, rack and pinion assembly + bushings & fluid under 20k miles. I have hard time believing it would be shot, but there is a possibility.
  6. Sep 17, 2024 at 11:58 AM
    DoktorSlowburn
    Escondido, CA
    Oh you replaced the whole rack already? Sorry, I must have missed that. Still though, like you said there’s a chance the rack may have been DoA, slim as it may be.
