Steering Rack Bushings
Discussion in '1st Gen. Tacomas (1995-2004)' started by ohmandrew, Nov 8, 2014.
  1. Oct 13, 2015 at 6:48 PM
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    Wow...pretty quick repair.
    A shop quoted me four hours of labor, including the alignment.
  2. Oct 13, 2015 at 7:17 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    I dont think an alignment is really required but your steering wheel may be off a little.
  3. Oct 13, 2015 at 8:04 PM
    Gooch
    Orange County CA
    FWIW, two one-star reviews on that product. One sounds like what you experienced:
    Does not fit
    I couldn't get the center bushing to fit, it is about 1/8" too wide, even with a press I ended up just mangling the urethane bushing. Waste of an afternoon and now I need to return it and get another brand shipped while my 4Runner sits in an inoperable state. I'll never buy Dorman again.
    The other guy wasn't happy either:
    Passenger side bushing does not fit.
    [​IMG]Summit Racing Verified Purchase
    I tried to install the passenger side bushing. It is to big. I spent 3 hours trying to do everything I could to make it work. I could not line up the two bolts that fasten the bracket over the bushing. This is the biggest bushing out of the 3 bushings on thesteering rack. I have not tried the other two bushings as I am afraid they will not work either. I will never buy dorman products again. I am Very dissapointed. Waste of my money.
    I will likely get genuine Toyota parts if they are available and not ridiculously expensive.
  4. Oct 14, 2015 at 3:33 AM
    devinzz1
    devin
    2023 aclb trd or mt
    kit i used. http://www.ebay.ca/itm/180839448548?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    fitment was great.
  5. Oct 14, 2015 at 5:39 AM
    bowyer2002
    bowyer2002 always tinkering
    NE Missouri
    01 Taco SR5 D-cab 4WD
    OME 882s, OME shocks all around and OME Dakar spring packs, ARB, Warn 8000, ARE shell, Custom rear bumper w/ reciever, 5-235/80R17 Cooper Discoverer ST MAXX on FJ wheels, grey wire mod, Hi-Lift, Hellas, Red-Line hood lifters, Scion radio, sliders, Safari snorkel & LED Ditch lights on CBI mounts.
    I got my bushings from O'reilly Auto and they fit fine.
  6. Oct 14, 2015 at 7:08 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    When I did mine last year I just jacked up the front and left the TRE intact. I replaced the sway bar bushings at the same time so it was out of the way while I did the rack. no alignment is necessary since nothing was changed on the ITR or OTR.
    funny thing is my center and passenger side bushing were "ok" but the lower driver side one looked like pudding when I turned the wheel. guess that northern salt bath every year helps
  7. Oct 14, 2015 at 8:04 AM
    Gooch
    Orange County CA
    For those that went urethane...any downside? Perhaps more road vibration in the steering wheel?
  8. Oct 14, 2015 at 10:27 AM
    Gooch
    Orange County CA
    The picture of the OP's kit shows a washer. The Prothane does not, and a reviewer on Amazon said that this was an issue. Was it for you?
    you will need an extra washer with this set, one of the factory long shaft washers was welded to the sleeve shaft.
    i cut it off with a metal cutting wheel and used it. you need 2 washers on this bushing...
  9. Oct 14, 2015 at 10:35 AM
    devinzz1
    devin
    2023 aclb trd or mt
    Didnt come with washer. Just reuse old one or buy one for 50 cents at hardware store. Probably isnt even needed as they are very stiff.
  10. Oct 14, 2015 at 10:38 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    you can re-use the factory one if it's not rusted out. the ES kit comes with one that goes between the rack and frame and you re-use the outer factory one.
  11. Oct 14, 2015 at 3:52 PM
    Gooch
    Orange County CA
    Good to know. Thanks.
  12. Oct 14, 2015 at 4:39 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    Yes, do not forget the washer between the rack and the frame. I read somewhere that it is very important. My 1st set came with new washers, the second set years later did not, lucky I saved my old ones.
    alphabravo likes this.
  13. Nov 5, 2015 at 8:34 AM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Just finished this job. I have to say it completely failed to live up to the hype. Everyone said it was a huge PITA, but mine didn't put up much fight at all. I used Energy Suspension poly bushings and they went right in. I suspect what is probably causing most people trouble is they don't clean out the holes in the rack where the bushings go. Mine were pretty nasty with corrosion and dirt that had fossilized into something like concrete. I cleaned and polished the holes with Scotch-brite (though for the driver's side one, I had to use a half round file to scrape off the concrete-like dirt before I could finish it with the Scotch-brite). Once they were smooth, I smeared some moly grease on the insides to inhibit corrosion and help the bushing slide in. Likewise, I greased the bushings and sleeves and was able to put them in by hand. No need for clamps, presses, or nuts and bolts.
    Anyway, it did put up a weak struggle when I went to put the rack back in place, but I soon figured out it was the tires causing the issue (I didn't take the tie rods loose, though the tires were off the ground). They had toed out a bit when I had pried the rack away from the crossmember. I found that I could kick them back out and the rack sucked right back into place on the crossmember. I had no trouble getting the bolts back in at all.
    All in all it was a pretty simple job. Thanks to the OP for this thread letting us know what to expect.
    Tomorrow, I'll be changing my inner tie rods. I don't expect that to be too difficult so it's probably going to fight me tooth and nail, haha.
  14. Nov 5, 2015 at 11:39 AM
    Gooch
    Orange County CA
    I think you just answered a question I had, which is, where does the rack want to go once you unbolt it? It sounds like it wants to go towards the rear of the vehicle.
    It does not want to fall downward, correct? Also, is there at any time any strain on the P/S lines?
  15. Nov 5, 2015 at 1:10 PM
    #35
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    The rack won't go down unless you pull the stud on the passenger side like OP. I have had my tie rod ends off so many times that they are pretty easy to pull. Then you can slide the rack to the rear and off the stud without having to remove it.
    Of course if you have a sway bar then that might require removal of the stud anyway since you will probably need to drop the rack downward rather than toward the rear.
    I have the ES kit coming from LowRange so I will be doing this soon.
    Nice writeup by OP.
  16. Nov 5, 2015 at 2:43 PM
    #36
    Taco No Baka
    Lee
    Tampa, FL
    Alphabravo is correct. Moving the rack anywhere takes some persuasion. I used a 2' pry bar too get it away from the crossmember (it actually move aft and down slightly) far enough that I could get the old bushings out. Also, I didn't have to take that stud the OP removed on the passenger side either. It's yet another side benefit to the sway bar delete. You pretty much get unrestricted access to the steering rack. BTW, you can take the D-shaped clamp off without moving the rack much. It just might take some patience to get it wiggled off the stud.
    Again, I didn't disconnect my tie rods, but I could see where it would maybe give you a bit more wiggle to play with...and ironically in my case, I wasn't really saving anything (time or cotter pins) by not removing them since the next step, replacing the inner tie rod ends, will require my to pull them anyway. :rolleyes:
    Lastly, I didn't have any issues with the PS lines. The steering shaft and tie rods prevented the rack from moving far enough to really have to worry about them.
    Oh, and also, I used a ball joint press to remove the center bushing. It came out pretty easy and a C-clamp with a large socket probably would have worked fine. My center bushing was pretty tore up though. The driver's side bushing I removed by sticking a short socket extension in it and driving it through with a BFH similar to how the OP did it only a little more hands free. Could do it with a bolt as well as long as the head fits through the bushing hole.
    Good luck with yours. Hopefully it goes as smoothly as mine did. :cool:
  17. Nov 27, 2015 at 4:52 PM
    #37
    Gooch
    Orange County CA
    I tried to do this today. Broke a Craftsman 19 mm 12-point socket trying to loosen the fastener for the center bushing. Thankfully, it was the first thing I did.
    I just ordered a Tekton 6-point to replace it.
  18. Nov 27, 2015 at 6:54 PM
    #38
    Taco No Baka
    Lee
    Tampa, FL
    That one was pretty tough as I recall. I used a 1/2" drive shallow well Craftsman socket on my ratcheting breaker bar (a 1/2" ratchet head pinned to a 16 inch breaker bar handle) with an 18" cheater pipe over the end of that to get it broken loose. Also, remember, the acetone/ATF juice is your friend. Make sure you splooge all the bolts down with that beforehand. PB Blaster is like unto water compared to this stuff.
  19. Nov 27, 2015 at 7:15 PM
    #39
    devinzz1
    devin
    2023 aclb trd or mt
    My oil leak made it so my bolts come off nice and easy ahaha
    Taco No Baka[QUOTED] likes this.
  20. Nov 27, 2015 at 7:28 PM
    #40
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    surprisingly enough you can break the welded nut from the bottom on the center :D
    only takes a 22 or 23 mm IIRC
