Steering Rack Bushings
Discussion in '1st Gen. Tacomas (1995-2004)' started by ohmandrew, Nov 8, 2014.
  1. May 10, 2016 at 8:04 PM
    #61
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    Same issue with my castle nut. Too low, making the cotter pin too high. Didn't think of adding a washer.
    Well that just sucks about the ES bushings. We'll see how long mine last. :(
  2. May 10, 2016 at 8:13 PM
    #62
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    I had that mysterious clunk / popping noise when I would turn left or right or turning either way when I was backing up. I replaced the rack and now the popping noise is gone. I put up with that noise for quite a long time and I'm glad it's gone! I also replaced both driver and passenger's side CV Axles and front wheel bearings when I did the rack, but doubt those things had anything to do with the noise. My driver's side boot had a 6 - 8 inch tear in it and the other side had a small hole while the driver's side bearing was going out so it only made sense to do both front wheel bearings at the same time. All noise is gone!
  3. May 10, 2016 at 8:46 PM
    #63
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Like I said, your mileage may vary. I have just about the worst set up for steering parts...33x13.50 Super Swampers, welded spiders, and I wheel hard. Still, I expected the poly bushings to hold up better than they apparently have. The factory stuff with 180k on it held up to that set up for 2 years.
    IIRC, I used a 5/8" steel flat washer. It was a little big around the outside, overhanging the steering arm, but it worked nicely to get the cotter pin fully engaged in the nut. :thumbsup:
  4. Aug 10, 2016 at 2:02 PM
    #64
    lve2xlr8_mph
    lve2xlr8_mph Silver Machine
    Tyler
    Zebulon, NC
    2004 Tacoma 3.4 V6 Limited
    Bilstein 3" lift
    I am in need of replacing my bushing, so what does everyone recommend OEM rubber bushing or going after market poly bushing or what??? 200K miles
  5. Aug 10, 2016 at 2:08 PM
    #65
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    poly for the steering rack for sure.
  6. Aug 10, 2016 at 2:13 PM
    #66
    lve2xlr8_mph
    Tyler
    Zebulon, NC
    Bilstein 3" lift
    Does the poly just last longer? What brand do you recommend?
  7. Aug 10, 2016 at 2:23 PM
    #67
    devinzz1
    devin
    2023 aclb trd or mt
    poly should last longer. the material is harder so in theory the steering should be a little more responsive but youd never be able to feel i dont think.
    energy suspension has the nicest kit imo.
  8. Aug 10, 2016 at 2:35 PM
    #68
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I prefer the kit from Wheelers becuase it has more than one sleeve option. This assures one of them will work in your application.
  9. Aug 10, 2016 at 3:22 PM
    #69
    Gooch
    Orange County CA
    Are the OEM rubber ones even available?
  10. Aug 10, 2016 at 3:27 PM
    #70
    Gooch
    Orange County CA
    I agree. Several people claim tighter steering but they went from trashed rubber to new poly. Two variables.
    I went from not-so-trashed rubber to new poly and noticed zero difference.
    For the people that noticed a huge difference, it might've been mostly because their old bushings were in such bad shape.
    Just MHO.
  11. Aug 10, 2016 at 3:27 PM
    #71
    lve2xlr8_mph
    Tyler
    Zebulon, NC
    Bilstein 3" lift
    well maybe not OEM but they do have rubber, poly, and thermoplastic
  12. Aug 10, 2016 at 3:30 PM
    #72
    lve2xlr8_mph
    Tyler
    Zebulon, NC
    Bilstein 3" lift
    yes mine are not trashed but i do have a good amount of play. my local part shop have the same types of bushings available as wheelers and energy. should i go energy poly or moog thermoplastic
  13. Aug 10, 2016 at 3:31 PM
    #73
    Taco No Baka
    Lee
    Tampa, FL
    Well, I dunno. You got 200k out of your factory bushings. Might be best to go back with those. I replaced mine with the energy suspension poly bushings and less than a year later, with no more than 1500 miles on them, the big wrap-around bushing split apart in the middle where the clamp sits. Of course, you have to understand, I have just about the most hellish setup possible for being hard on steering parts (welded spiders in the front diff, 33x13.50 Swampers on 8" wheels with 3.5" of back spacing and about half my mileage is off-road) so your mileage may vary. :D
    I know I, for one, am probably not going to put any more aftermarket steering parts on my truck unless I have no other option. Not even Moog parts seem to last a fraction of the life of the genuine Toyota parts.
  14. Aug 10, 2016 at 3:43 PM
    #74
    Gooch
    Orange County CA
    Excellent point. That same logic applied when I replaced my original rear brakes at like 120K.
    Taco No Baka[QUOTED] likes this.
  15. Aug 10, 2016 at 4:12 PM
    #75
    lve2xlr8_mph
    Tyler
    Zebulon, NC
    Bilstein 3" lift
  16. Aug 10, 2016 at 4:26 PM
    #76
    Taco No Baka
    Lee
    Tampa, FL
    That's where I got my Energy Suspension bushings (Rockauto). They are a good place to get good prices on aftermarket stuff. Again though, I think I'd shell out the cash for the genuine Toyota parts. As far as Rockauto, if I can find parts made by a OEM manuafacturer (Denso, Aisin, Koyo, etc...) I figure those will be almost as good as the factory parts. Otherwise, you just have to take your chances.
  17. Aug 10, 2016 at 9:10 PM
    #77
    retroboy1989
    retroboy1989 Single Cab 4x4
    99 2.7L 5spd 4x4
    I originally used the Dorman kit used by the OP. I found it to be a poor fit. I swapped it out for the Energy Suspension kit and was much happier. It was actually cheaper!!
  18. Aug 10, 2016 at 9:53 PM
    #78
    devinzz1
    devin
    2023 aclb trd or mt
    I find dorman products 50/50 when it comes to quality. Some parts are great and others arent. Some are garbage...
    Taco No Baka likes this.
  19. Aug 10, 2016 at 10:02 PM
    #79
    Taco No Baka
    Lee
    Tampa, FL
    Same here. I replaced my lower ball joint-to-spindle bolts with a set of Dorman M10x35mm grade 10.9 flange head bolts and they worked perfectly. I think my air filter box was Dorman too. No complaints about that yet. Door handles and whatnot...not so much.
  20. Aug 11, 2016 at 10:13 AM
    #80
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
