Steering rack clamp bushing movement?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1997tacomav6, May 5, 2021.
  1. May 6, 2021 at 1:02 PM
    TacoBike
    TacoBike The Researcher
    Mason
    Shingle Springs, California
    2000 3.4 Ext Cab TRD 4x4 with original SC
    ARP head studs Supercharger FIC6 AFR gauge painted fenders audio install
    replacing metal (fenders) with rubber now are we?
  2. May 6, 2021 at 1:03 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    fenders?
  3. May 6, 2021 at 1:03 PM
    TacoBike
    Mason
    I mean when you cut them half to hell.... You replace the void with rubber
  4. May 6, 2021 at 1:09 PM
    jbrandt
    Justin
    Cutting sounds like a lot of work. Just remove them.
    Thank you for coming to my Ted Talk.
    :D
    POSTacoMike, Abeyancer and Kwikvette like this.
  5. May 6, 2021 at 1:11 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    I replaced a 1st gen taco rack few months back. OEM rack, bushings, etc. Rack would move side to side in that bushing OP has pictured. Triple checked everything was installed properly and torqued to spec. Loosened everything and torqued again same problem. Test drives just fine. I recommended poly bushings at that point.
    This isn't the first thread I've seen on this. If be very interested to know why this happens.
    Have someone turn the wheel while you stay under the truck watching the rack. I bet it's moving.
  6. May 6, 2021 at 1:18 PM
    TacoBike
    Mason
    Fenders?! Where we're going we dont need fenders. @Kwikvette
    POSTacoMike and Kwikvette like this.
  7. May 6, 2021 at 1:19 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Can't fit 44s if you're running fenders :burp:
    Getting rid of that bed too amirite
    POSTacoMike likes this.
  8. May 6, 2021 at 1:23 PM
    TacoBike
    Mason
    Someone comes to mind here... His name is @POSTacoMike !
    but anyway why even have a hood at that point... too much weight
  9. May 7, 2021 at 9:00 AM
    Boone Wesley
    Boone Wesley Well-Known Member
    Boone
    LA 818
    01 4D 4WD Limited
    Were you around to see if the poly fixed it?
  10. May 7, 2021 at 11:00 AM
    Superdave1.0
    SoCal
    No, don't think they replaced with poly. I'd bet poly bushings help quite a bit.
