Steering rack clunk and slop
Discussion in '2nd Gen. Tacomas (2005-2015)' started by idano, Oct 26, 2022.
  1. Oct 26, 2022 at 12:11 PM
    idano
    idano [OP] Member
    Dan
    Round Rock, TX
    2011 Taco 2.7 Prerunner Silver Streak Mica
    It’s not the tie rods as both wheels move together as I grab at 9 & 3 and push/pull side-to-side. The attached video is the view from underneath as I move the tire (either side acts the same). What is causing this? Do I need a whole new rack or is this adjustable? It doesn’t look like it a bushing issue as the rack itself isn’t moving. It looks like internals are loose. If so can this be adjusted?
  2. Oct 26, 2022 at 2:25 PM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    Preload is adjustable..not easy to access and not advisable. I'd look for other issues. How many miles? Any leaks? Lots of serious off-roading?
  3. Oct 27, 2022 at 10:39 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    It looks to me like your rack assembly is in fact moving a little bit from side to side. Im pretty sure these are bushing mounted, so Id imagine a little play is normal.
    More importantly though, is the steering wheel held 100% tight in the same spot when you are doing this test? If not the tires can spin the wheel a little bit
    CTSpruceMica likes this.
  4. Oct 27, 2022 at 5:30 PM
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    Thought I saw the shock moving up and down, then realized the camera angle was from below, not the side. Just the CV boot moving as expected. :facepalm:
  5. Nov 7, 2022 at 1:13 PM
    idano
    idano [OP] Member
    Dan
    Round Rock, TX
    Nothing moves except the wheels together as I move either one side or the the other side to side. Neither the steering wheel or the outside of the steering rack housing move.
  6. Nov 28, 2022 at 6:38 AM
    tacomavan
    tacomavan Well-Known Member
    Oregon
    i notice the same when i was troubleshooting what i thought was a wheel bearing going bad. Used a ratchet strap to secure my steering wheel and did the 9/3 12/6 hand dance with my tires and noticed how much play there was
  7. Nov 28, 2022 at 7:49 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Slider bushing preload. Mark where it currently is, Pull it out, clean it, regrease the rack sliding surface and the bushing, and tighten down back to where it was + a little more (1/8th of a turn), if slop is gone, good, if not, tighten further. Too tight and the steering wheel wont return back to center.
