Steering rack clunking
Discussion in '1st Gen. Tacomas (1995-2004)' started by TACO TX, Sep 10, 2013.
  1. Sep 10, 2013 at 7:22 PM
    TACO TX
    TACO TX [OP] Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    I have had issues with my truck walking and tracking on its own for months now, i have replaced the rack bushings, had an alignment and still does it. So i have been thinking tie rod ends and they seem to be tight as well as all ball joints, today when i did the dry steer test with the bellows boots off i could here a clanking noise when i would turn the wheel back and forth. It seems to be play in the steering shafts inside the rack. Here is a video i found of it, this is not my vehicle but this is what it is doing. Is the rack toast. Oh and its leaking on the passenger side a little but not leaking out of boot. Just a little fluid on the shaft and inside the housing. The driver side shaft has like milky grease smeared on it. But hey, on to the clunking. http://youtu.be/0uB86ruIblE
  2. Sep 11, 2013 at 1:40 AM
    Yeticoma
    Yeticoma Member
    Scott
    Oahu
    01 PreRunner SR5
    I just started hearing the same knocking in mine a couple days ago. did some googling but this is the closest i've found yet. i'm taking mine in saturday to get it looked at.
  3. Sep 11, 2013 at 2:16 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Look like the rack will need to be replaced. You can try adjusting the preload.
  4. Sep 11, 2013 at 6:09 AM
    TACO TX
    Kelly
    Denison ,Texas
  5. Sep 11, 2013 at 6:10 PM
    fpradojr36
    fpradojr36 Well-Known Member
    J.R.
    90804
    04 Prerunner, 2019 TRD 4x4
    I would just go aftermarket. My friends works at toyota and with his discount its still like over $500. I found a few online all around $300. Plus I'm still going to buy outer tie rod ends and bushings for my 04 tacoma. At least it lasted this long 172,000.
  6. Sep 11, 2013 at 7:14 PM
    TACO TX
    Kelly
    Denison ,Texas
    Yea, what im thinking, i got 173,000 out of mine, a couple lifetime warranty ones on ebay for like $250
