Steering rack issue/question
Discussion in '1st Gen. Tacomas (1995-2004)' started by ChrisYoTaCoMa, Nov 15, 2009.
  1. Nov 15, 2009 at 5:02 AM
    ChrisYoTaCoMa
    ChrisYoTaCoMa [OP] Chrome's for Harleys and old farts
    Estero, Floriduh
    00 Taco 4x4 Ex cab 2.7 sr5 AT
    New Pioneer stereo, and all 4 speakers with Infinity components. Sirius satellite radio. Deckplate mod done. Door buzzer silenced forever thank God, tinted windows, vent visors, hood protector(bug guard), ceramic pads and new rotors, dechromed EVERYTHING. 2" Lift front 3" rear. Skyjacker AAL's and replacement leafs(and front spacers) from Fatbobsgarage.com. Skyjacker 7000 Hydro rear shocks, those Bilstein 5100 fronts are coming soon!
    Can the steering rack guide be adjusted? It's in the bottom pic on the NCTTORA manual below.
    Mine has a little play at that end of the rack, it's not a tie rod end, the one on that side is new(inner). When I pull the rack boot back and turn the tire/wheel back and forth by hand there is a tiny bit of play at the end I can see. I can feel it in the steering wheel, but just a little bit. I see the cap and spring in the manual, and want to know if it is just an adjustment I can do, or do I have to replace the whole $400 rack, YAY!!!
  2. Nov 15, 2009 at 5:09 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Are you sure the play you are feeling isnt from worn rack bushing? I would check those first.
  3. Nov 15, 2009 at 5:15 AM
    ChrisYoTaCoMa
    Estero, Floriduh
    I was hoping you would chime in here.
    Nah, I am going to replace those too, but... When I pull the boot back and look into the end where the main shaft(rack) comes out of the housing, I can see a small bit of play there. Is there supposed to be a little play there? Or do you think I should first replace the bushings?
  4. Nov 15, 2009 at 5:16 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    There should be a little bit of play. Not much, as the guide is just that...A guide. If its too tight, it can cause wear on the shaft, and eventually leak.
  5. Nov 15, 2009 at 5:19 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Keep in mind, the looseness you may be feeling could be the guide spring compressing and extending.
  6. Nov 15, 2009 at 5:19 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    IF, and this is very unlikley, you feel there is too much play, you can replace the spring guide spring.
  7. Nov 15, 2009 at 5:21 AM
    ChrisYoTaCoMa
    Estero, Floriduh
    hmmm? So i wonder if the new bushings will stop the play in the steering wheel? It's not bad, but annoying. the steering is tight, not like a worn tie rod or LBJ. Now.... Another thing. When I rotated my donut tires(i call them that because they are so frickin small after the lift), I feel a slight cupping on my outer tire edges after the 4K mile rotation. LBJ's, tie rod ends?????? And I had the alignment done after my lift at a 4 wheel shop.
  8. Nov 15, 2009 at 5:21 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Is the entire rack moving? How are your rack bushings? (common problem)
  9. Nov 15, 2009 at 5:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I really doubt its the LBJ's.. Those are pretty stout units. It "could" be the TRE's, but first, get an alignment if you havent had one in a while.
  10. Nov 15, 2009 at 5:23 AM
    ChrisYoTaCoMa
    Estero, Floriduh
    had the alignment done in June after i did my lift. Which i will have to do again after I put in the 5100's...
  11. Nov 15, 2009 at 5:26 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Can you send me/post a pic of the cupping? If tire pressure is incorrect, that could also be a cause....
  12. Nov 15, 2009 at 7:02 AM
    ChrisYoTaCoMa
    Estero, Floriduh
    I'll try to get you a pic of the tire. It's not too noticable, but when you run your hand on it, you feel it.
    I just ordered a set of red rack bushings.:) They look pretty easy to replace, probably easir than my ex's sebring... Any pointers I need to know when I replace them?
  13. Nov 15, 2009 at 7:03 AM
    wherestaco
    wherestaco Well-Known Member
    matt
    annapolis md
    oo taco std cab 3in lift
    allpro trail armor, allpro 3inch lift, 33 1250 ssr, k&n intake, flowmaster exhaust, mile marker 9500, 4.88 yukon gears spartan lunch box in the front detroit in the rear,procomp 55w lights, mild port work.
    you can adjust the tension but you have to get it just right to lose will wear out and skip teeth to tight and the shaft could snap and you have no steering. I have had this problem with mine if you replace the rack get a toyota not reman I'v gone threw 4 remans in a year
  14. Nov 15, 2009 at 7:09 AM
    ChrisYoTaCoMa
    Estero, Floriduh
    Oh hell no, if I have to replace it I want to do it once... I will buy OEM for sure.
    I'm afraid to mess with it. I am going to replace my bushings and see what that does for it.
  15. Nov 15, 2009 at 8:21 AM
    Janster
    Jandy
    Lancaster, PA
  16. Nov 15, 2009 at 8:27 AM
    Janster
    Jandy
    Lancaster, PA
    Are you saying.....immediately after you rotated the tires, you feel the cupping?
    Or are you saying that after 4,000 miles, you feel cupping?
    Cupping can be from worn out shocks/struts. You mentioned you just got a lift? Did you replace the shocks/struts?
    What type of tires are you running and how many miles are on them?
    I had a weird cupping problem in the past on my 96 and I swear it was due to the tires being old....and they just wore funny the closer they got to their limit. (Dueler AT's). I had virtually new shocks/coils (OME) and had allignment done, rotated properly, etc. No other explainations why they were cupping.
  17. Nov 15, 2009 at 11:08 AM
    ChrisYoTaCoMa
    Estero, Floriduh
    Well...
    The tires are 235/75/15 Kumho KR21's. They were bought new in May and have about 5K on them. I bought these tires with the thinking I was keeping it at stock height(ha ha yeah right...LOL), and being here in FL, there isn't a whole lot of off roading. Well long story short, I had to replace leafs, lifted it, and now the tires look like frickin donuts... I did the 4K rotation as recommended. So after 4K I feel the cupping. But it's not bad, just light cupping. I will be replacing these tires with new 31's or32's(haven't decided yet) and new wheels. So I want the front end right as to not screw up the new stuff.
    My front struts are new also, stock type Gabriels, and are going to 5100's right after Christmas. Did the spacer lift thing, and had it aligned the day after at a 4x4 shop. Like you say it might be the way they wear. On the other hand... When my brother in law owned it, he had a set of Wranglers on it and they were cupped, feathered, just FUBAR... The thing with him is he never rotated them in 4 years.... LOL.
  18. Nov 15, 2009 at 1:00 PM
    Janster
    Jandy
    Lancaster, PA
    You've rotated them once or twice?
    When you say you *feel* the cupping...what do you mean? Do you feel a vibration? Does the vibration change when or if you rotate the tires again?
  19. Nov 15, 2009 at 1:36 PM
    ChrisYoTaCoMa
    Estero, Floriduh
    You know how if you run your hand flat on the tread? The outer edge has that feathering feeling on the outer tread. Like each tread block is a bit lower on each edge. Here is a pic of what I mean.
  20. Nov 16, 2009 at 4:12 AM
    ChrisYoTaCoMa
    Estero, Floriduh
