Steering rack issue?
Discussion in '1st Gen. Tacomas (1995-2004)' started by woad4, Mar 10, 2024.
  1. Mar 10, 2024 at 5:07 PM
    woad4
    woad4 [OP] Well-Known Member
    2003 Tacoma Xtra Cab
    3rzfe
    C9E58775-58D4-465D-A281-9BD4104CA837.jpg I just got done replacing the bushings in my steering rack and lower control arms. I had to tilt the rack at a pretty extreme angle to replace the cam bolts on the lower control arms.
    When I tilted it, oil started to come out of the rack and fill the boot.
    is that normal? The truck is newish to me, I'm not sure if it's ever leaked before? Or is that indications seals are going out on the rack?
    I circled the area the oil was sitting
  2. Mar 10, 2024 at 7:59 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    YO woad4
    fill out your profile so others can see what age/engine you’re taco is!
    IMO, I would expect some fluid to seep out bc of extreme angle and old inr rack seals thou
  3. Mar 10, 2024 at 8:05 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Turn on the truck and cycle the rack lock to lock a few times. See if it leaks.
    Superdave1.0 and ControlCar like this.
  4. Mar 10, 2024 at 8:14 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Just replaced steering rack today on my Land Cruiser. There shouldn't be any fluid coming out of there. My rack sprung a huge leak right there and pissed all over my driveway last week.
    I've replaced the rack in 1st gen Tacomas several times. Compared to my Land Cruiser, it's a walk in the park.
    They are a wearable part that Tacomas usually need every 100-200k miles. I recommend an OEM new part.
  5. Mar 10, 2024 at 8:38 PM
    woad4
    3rzfe
    Good advice, I should have done that ages ago with my profile. Thank you
    ControlCar[QUOTED] likes this.
  6. Mar 10, 2024 at 8:41 PM
    woad4
    3rzfe
    Silly question, do you know if its safe to remove my steering wheel from the lock position?
    I'm doing my tie rods (inner/outer) power steering bushings, shocks, upper and lower control arms, ball joints etc etc.. The only thing re-connected at this point is my power steering rack. The instructions i've read say to keep your steering wheel locked throughout the procedures.
    I should be able to unlock it and perform your test as long as my power steering rack is 100% connected? I cant imagine what it would mess up if i dont have my tie rods, or rest of suspension set up?
  7. Mar 10, 2024 at 8:44 PM
    Superdave1.0
    SoCal
    Yes you can unlock the wheel and turn the rack lock to lock. Whether or not the outer tie rods are connected won't hurt the rack or anything else. As long as your steering shaft is bolted to the rack you are fine.
  8. Mar 10, 2024 at 8:45 PM
    woad4
    3rzfe
    You aren't kidding, I just got done watching a video on the 1st gen tacoma power steering rack replacement. It really doesn't look to bad, especially where i'm at with my tear down, its not much additional work.
    Where was your leak at? I agree! from my basic knowledge of racks, it shouldn't have a leak anywhere. But i've never found oil under my truck in any form, and what are the odds as soon as i maneuver the rack it begins a leak.
    I was hoping it was just because the angle? In reality, i think its just a matter of time before it starts a real leak?
  9. Mar 10, 2024 at 8:47 PM
    Superdave1.0
    SoCal
    From my understanding there should be zero power steering fluid outside of the rack. You likely didn't see any leaks because the boot makes a good seal, and fluid lived inside the boot, not leaking out.
    I'd guess you have a slow leak there that will get bigger. As stated try turning the rack and see if fluid comes out. Having the engine running is even better, because that will pressurize the system.
  10. Mar 10, 2024 at 9:13 PM
    woad4
    3rzfe
    Stole my wifes q-tips cleaned every spec inside the barrel there, cycled steering rack 4-5 times, not a drop.
    Might be worth noting the oil that came out of the boot was crystal clear, looked like brand new oil. It definitely wasn't in that boot long.
  11. Mar 10, 2024 at 9:18 PM
    Superdave1.0
    SoCal
    Can run it for a while and open the boot up maybe in a week or 2. See if any fluid has come out. If a couple weeks goes by and it's dry you should be good.
    Strictlytoyz likes this.
  12. Mar 10, 2024 at 9:27 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    I'd say run it and as @Superdave1.0 stated just monitor it. Could be on the way out. I ran a leaky rack for years lol
  13. Mar 10, 2024 at 9:29 PM
    woad4
    3rzfe
    Thank you both for the advice, i really appreciate it.
    ControlCar likes this.
  14. Mar 11, 2024 at 4:50 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    I recently replaced my rack at 210k miles because there was fluid coming out both ends. Both boots had worn through from wear over 25 years and that’s how I saw the leak. Who knows how long it was leaking at that point. I figured if it’s old enough for the boots to be worn through, I should probably replace the whole thing.
    Superdave1.0 likes this.
  15. Mar 11, 2024 at 8:09 AM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    @woad4 if the fluid coming out was crystal clear you have the wrong fluid in there. Our power steering systems call for DexIII ATF (which is red in color, turns dark dark red, to black over time). Might be worth draining your system out and adding the proper fluid unless you expect to change out this rack soon, as that's the easiest time to do that.
    Superdave1.0 and Strictlytoyz like this.
  16. Mar 11, 2024 at 10:25 AM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    Well, if you have/are planning to disconnect the shaft from the rack output spline, you should have the steering wheel rope-locked in exactly dead center, key-lock is rarely center. Two things can go wrong. When you put it back together you may find the steering wheel will be at an angle to drive straight. One way to fix that is to over-adjust the TRE's, but then your TRE threads will differ on the two sides (not a huge deal.) The other is to remove the shaft from the rack again and adjust it by trial and error.
    A new rack will have witness marks for the dead center position of the rack. Having the shaft roped to dead center will ensure you're pretty close on re-assembly.
    The other thing that can go wrong is with everything loose the clock spring in the steering column can get too far to one side or the other. The result can be that turn signals don't cancel, or worse, a tight turn can break the clock spring and that's a bit expensive. Best to keep it rope-locked to center. I use ratchet straps anchored to the seat frames.
