steering rack leak...
Discussion in '1st Gen. Tacomas (1995-2004)' started by Toyota4x46921, Feb 26, 2014.
  1. Feb 26, 2014 at 1:33 PM
    Toyota4x46921
    Toyota4x46921 [OP] Well-Known Member
    Michael
    Warner Robins, GA
    Well after my alignment ordeal at Toyota ...I got up under my truck and noticed a dent on the back of my skid plate near the steering rack. Also there is fluid leaking out of the part that screws into the rack...I attached a picture. Wasn't sure if the steering rack is on its way out or it got bumped at the dealership and just needs tightening.
  2. Feb 26, 2014 at 4:43 PM
    nigglewiggle60
    nigglewiggle60 Well-Known Member
    Nigel
    Oakhurst, CA
    2004 DC 4x4 TRD
    Rubber mats, Bluetooth.
    Haha, I just had a shop check out my rack for this same issue. It is a 33mm hex I think they said. They tightened it and the steering wheel had no play. They backed off a little and the steering loosened up a bit. They think this is some type of adjustment screw. But after tightening a little the drip stopped.
  3. Feb 26, 2014 at 5:42 PM
    Toyota4x46921
    Michael
    Warner Robins, GA
    Alright I will tighten it a little tomorrow
  4. Feb 26, 2014 at 9:08 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    I don't think theres any fluid in there, just grease. Heres a write up, you could just pop it out, put some silicone on the threads and re torque it. Are you sure the leak isn't coming from inside the boots or the input seal?
  5. Feb 27, 2014 at 4:16 AM
    Toyota4x46921
    Michael
    Warner Robins, GA
    I caught myself looking but I will pop the boot off and look at everything today
  6. Feb 27, 2014 at 1:28 PM
    Hektor
    Hektor Well-Known Member
    Texas
    04 Tacoma 4x4 TRD DC v6
    Sub'd
  7. Feb 28, 2014 at 9:19 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    O.P.
    That is the rack and pinion gear preload adjuster. There should be no fluid behind it or leaking from it and there is a procedure to adjust them. They are intended to be installed with a thread sealant to keep contaminants and water out.
    If there is fluid in that area of the rack it means there is a leak from the driver side "rack end seal" or the "lower control valve shaft seal". There is a very slim chance some oil could be present that has separated from the grease used on the gears and rack guide. These things are frequently over greased. Again, that's a remote possibility.
    It might just be the photo but it looks like a zip tie on the boot. This should raise some suspicion that someone has been in there before. These boots are far from waterproof even with a good clamp and rust pitting is one of the main causes of rack seal failure. More investigation is needed.
    Most folks would not rebuild their own rack but this link will provide some photos, a boots off inspection procedure and some understanding of what goes on inside the rack that might help your plan of attack. Your rack has the new style guide but you didn't mention your year so it could be factory or an upgrade.
    http://www.tacomaworld.com/forum/1s...rack-pinion-service-tools-tips-dry-wordy.html
