Steering rack Leak
Discussion in '1st Gen. Tacomas (1995-2004)' started by TechnoTy, Feb 4, 2017.
  1. Feb 6, 2017 at 12:12 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    I have heard decent reviews about that outfit and getting decent replacement racks. If i were in the market for a replacement id prolly get one through them.
  2. Feb 6, 2017 at 8:06 AM
    SnowB0und
    SnowB0und Well-Known Member
    4cyl 4x4
    I'll post some pix when it gets here, should be here any day.
  3. Feb 6, 2017 at 9:09 AM
    harper7
    harper7 Well-Known Member
    Gary
    Tulsa/Claremore OK
    00 Imperial Jade 4x4 TRD,01 TRD 5sp
    I bought a brand new AAE 3273N steering rack when I replaced mine last year for $250 shipped with no core charge. It''s only been 6 months and perfect so far.
    I researched at the time and found this thread over in my old T4R stomping grounds that swayed me. 3rd gen 4x4 4runners are the same.Almost positive the AAE is the upgraded one Safari LTD sells too.
  4. Feb 6, 2017 at 9:16 AM
    1999RegCab
    1999RegCab Well-Known Member
    Cacti Land, AZ
    1999 Reg Cab, 2.7, 5 speed
    3-link SAS
    Eventually you get to the point in which you will hate dealing with this steering rack crap so much that you will want to do a SAS :D
    Well, the racks can go long ways in mostly street driven trucks that see mild off road use.
    But if you start wheeling a lot you will go through them.
    Sicyota04 likes this.
  5. Feb 6, 2017 at 10:12 AM
    99SuperTaco4x4
    99SuperTaco4x4 Well-Known Member
    1999 3.4L V6 Tacoma, 4x4, TRD Supercharger
    my rack is leaking. I had to replace PS fluid every week. Besides the environmental cost, it was messing up my driveway and annoying as fuck. The Lucas PowerSteering Stop Leak actually worked. It's been a month and a half since I put anything in the reservoir. Driveway is dry. I realize I will need to replace this unit eventually, but I am going OEM and thats $500 I want to put off as long as possible. Just a suggestion, YMMV
  6. Feb 6, 2017 at 10:22 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    +2 on the Lucas PS Stop Leak. swapped in a res worth, drove it week, swapped in another res worth & did that 1 more time. Mine was just starting to seep on one side. Have had no further seepage on the one side and no other seepages...........for a coupla years. When it cries I will give it a tissue but so far so good. On the 05 AC dealership charged me $350, while they were doing other free drivetrain warranty things, to rebuild mine since they couldn't seem to find one on the planet at the time to charge me $1100 for. (not that that woulda happened) I would have gone elsewhere for rebuilt.
    99SuperTaco4x4 likes this.
  7. Feb 6, 2017 at 10:52 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    How much did you put in? I have a slight leak (a drop on the pass side boot) and don't feel like dropping a chunk of change on an OEM one at the moment
  8. Feb 6, 2017 at 11:44 AM
    99SuperTaco4x4
    The bottle says put the whole thing in, and be ready to add another. Because I had some fluid already in the reservoir, and did not suck it out or drain it, I was only able to put half a bottle in. And that was 1.5 months ago and the level looks unchanged.
  9. Feb 6, 2017 at 11:48 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    I'd imagine you just wanna be sensitive to the fact that the required fluid is ATF and very thin. Too much of any type of thickener to stop leaks CAN, not necessarily will, overwork the pump and if pump can't keep up the rack is SOL and then possibly the pump as well. Not saying not too, I'd just try and turn the wheel only while tires are actually moving etc., as to alleviate as much additional stress from the thick fluid as possible.
  10. Feb 6, 2017 at 11:50 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Okay. Yeah I'd rather not overdo it. Half a bottle sounds okay
  11. Feb 6, 2017 at 1:25 PM
    99SuperTaco4x4
    Thats a very good point, and something I did consider. Thanks for making that point. I felt comfortable having mostly ATF fluid with approximately half a bottle of Lucas in there.
    quetzal and cruiserguy[QUOTED] like this.
  12. Feb 6, 2017 at 1:57 PM
    cruiserguy
    Elijah
    SEKS
    Cool, sounds like you're on it just fine.
  13. Feb 6, 2017 at 2:54 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I have a Cajun injector big syringe thing I saved for evacuating brake or ps resevoirs. I emptied my reservoir (no, not all the way to cause air in lines) then added lucas, then drove a few days then did the same thing 2 more times. At that point I had only used 1/2 to 2/3 of the bottle so the system never even got a whole bottle, much less all at once.
  14. Feb 6, 2017 at 4:00 PM
    cruiserguy
    Elijah
    SEKS
    Nice, sounds like a good plan, use as little at a time as possible, until you get the desired result. Definitely best way to do something like that.
  15. Feb 6, 2017 at 8:49 PM
    #35
    jacobrippey
    jacobrippey It’s always Taco Tuesday Instagram #rippstik
    Jacob
    Surprise, Arizona. USA
    2004 Tacoma DC 4wd
    Find me on Instagram: @rippstik
    I'm on rack #4. This is getting old.
  16. Feb 6, 2017 at 9:40 PM
    #36
    cruiserguy
    Elijah
    SEKS
    Wow, I hope they aren't O$E$M racks??
  17. Feb 7, 2017 at 5:06 AM
    #37
    jacobrippey
    Jacob
    2004 Tacoma DC 4wd
    Nope. Got it through eBay. Lifetime warrantee, which I have used 3 times :D
    #37
  18. Feb 7, 2017 at 5:50 AM
    #38
    TechnoTy
    TechnoTy [OP] Lets go Places yo
    Ty
    Colorado
    03 Tacoma Double Cab
    Thanks all. You guys informed me I got the wrong rack in order and I was able to cancel. Going to reorder tonight. Saving up for sas. Hopefully at the end of summer.
  19. Feb 7, 2017 at 7:09 AM
    #39
    cruiserguy
    Elijah
    SEKS
    Suuuuuuuck.
    #39
  20. Feb 7, 2017 at 7:13 AM
    #40
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    These prices are way lower than a price I was quoted at Napa. Not sure what brand it was but it was close to $500!!! I did not get that one.
