Steering Rack Mount Shot...what can I do?
Discussion in '1st Gen. Tacomas (1995-2004)' started by monkeyodeath, Apr 25, 2016.
  1. Apr 25, 2016 at 11:43 AM
    monkeyodeath
    monkeyodeath [OP] Well-Known Member
    Joshua
    Los Angeles
    2003 4x4 TRD
    Hi all,
    I knew that the previous owner of my 2000 had been in a wreck, but I've found a new, annoying issue from it...
    On the passenger side of the steering rack, there's a U-shaped bracket that holds it to the frame.
    The bottom bolt on this bracket screws into a welded captive nut inside the frame tubing.
    However, on my truck, this nut isn't attached -- it just spins around and is damn near impossible to secure. Before, I was able to jam a screwdriver in there to jam it and tighten the bolt, but at this point, it's all rounded over...
    My question -- what do you think is the best way to fix this? I can't get a socket or anything back into that area to hold the nut.
    I was thinking of using a grinder to cut away the indicated area in order to install a new nut and get a wrench around it. Thoughts?
    Pics:
  2. Apr 25, 2016 at 11:46 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    I had to cut the whole thing out and build a new one.
  3. Apr 27, 2016 at 10:30 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Looks to me like you did a pretty good job on it !
  4. Apr 27, 2016 at 3:24 PM
    monkeyodeath
    Joshua
    Los Angeles
    2003 4x4 TRD
    Holy crap, nice work!
    I definitely did not decide to go down such a route.
    I grabbed the angle grinder with a cutoff wheel and cut out just enough metal to get a flare wrench up there and hold the nut as I tightened it.
    I really don't think it will affect the structural integrity of the rack mount -- it was about an inch square of material. Might weld it back into place, might not.
  5. Apr 27, 2016 at 3:48 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    Could not hurt to weld some stock on it just to reinforce. Just sayin.......
