Steering rack needs to be replaced after 50K miles - 2019 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FranklinsDad, Dec 19, 2023.
  1. Jun 26, 2025 at 12:53 PM
    #61
    scocar
    scocar Patron of the Farts
    Wow.
  2. Jun 26, 2025 at 12:56 PM
    #62
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Sounds like Franklinsdad (OP of this thread) lives in a state with mandatory vehicle inspections, else he probably wouldn’t have had to replace his steering rack due to oil moistened boot interiors. I’m in a state that doesn’t, and won’t be replacing mine with the same issue of some oil seeped into the boots because the reservoir level hasn’t changed, the seepage is/was contained inside the boots, and because we don’t have to.
    tonered likes this.
  3. Jun 26, 2025 at 1:15 PM
    #63
    scocar
    On my 2015 DCLB 4x4 I had it in for service, and installing my lift, and swapping out the front diff needle bearing for an ECGS, all at my experienced go to shop.
    They noted minor leaking in the steering rack. I was suprised. on the one hand, they daid I could watch it. On the other hand, the front suspension was already completely torn apart so most of the labor related to the rack was already being spent. I asked about remans and a core swap, they said they never last and hardly anyone supplies them. Recommended OEM all day. They did do much business with the local dealer they worked on price and came out at $1200 for a new OEM rack.
    I went for it given the circumstances. I had some E rated Coopers on it for quite a while, plus the shit turning radius, I figured those were factors.
    Now I avoid 3 point a sharp U turns like the plague.
    Just thought you might find this experience illuminating.
    Canadian Caber likes this.
  4. Jun 26, 2025 at 1:16 PM
    #64
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I like you approach, but there is the pushy side. Not you, but others. We had our old car in for a quick brake and wheel bearing check. The shop went full anal and recommended over $4k in work. Some of it we elected to do since the car was $1,500mi away. They still send reminders about the rest to my wife.
    A balance is always tough to strike. It chaps me more because I could do it all if it was at home.
    b_r_o[QUOTED] likes this.
  5. Jun 26, 2025 at 1:18 PM
    #65
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    A little brake cleaner goes a long way. :rofl:
  6. Jun 26, 2025 at 1:25 PM
    #66
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I'm not in the receiving side of this stuff so its easy for me to forget what its like for the average customer..
    A lot of shops are shady but a lot of them are not, it can be hard to find a trustworthy place
    Best advice I can give is to avoid any kind of special or coupon haha. Seriously, run the fuck away..
    My oil changes are around $140-150 including tax. That may sound like a lot but i also won't push ridiculously unneeded crap.. I don't have to because i'm not tripping out over the time I'm spending on your little oil change. I'm relaxed, I don't need to rush. Also helps that
    we charge for diagnostics, we wont scan codes for free, etc. Its not healthy for the shop to give time away. It creates a situation where the shop has to go after it harder.. to make up the time they give away. Its a tough balance and it takes years to get it right
  7. Jun 26, 2025 at 2:24 PM
    #67
    OnHartung'sRoad
    You put that inside your boots?:notsure:
    tonered[QUOTED] likes this.
  8. Jun 26, 2025 at 2:39 PM
    #68
    pushgears
    pushgears Well-Known Member
    2021 OR DCSB MT
    I think it is relatively rare, but not unusual. My 2008 RAV-4 lost its steering rack right after its warranty ran out.
  9. Jun 27, 2025 at 6:06 AM
    #69
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    No. But, spraying down the outside could stop the questions.
  10. Jun 27, 2025 at 7:00 AM
    #70
    Williston
    Williston Well-Known Member
    2014 Tacoma DC SB 4x4 V6 040 [SL] SR5 Trim [ED] Entune Audio+ [TO] V6 Tow Package
    Stock (99.999%) OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Gentex Auto-Dim mirror w/Compass & Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All-Weather Floor Mats (summer).
    Keep bringing up and pointing out the issues you see. :thumbsup: I hate leaks and when I see one, I clean the area with MAF sensor cleaner, re-torque whatever fasteners are involved to just a hair under spec, and then watch it like a hawk. This usually cures it. If it comes right back and quickly progresses to what it was before, (area wise) the offending gasket gets replaced. If it takes several thousand miles to match what it was before cleaning I leave it alone and watch it until it does.
    That said, My 2014 currently with 140,000 on it has had no oil leaks. Mobil1 5w30 full-synthetic or equivalent. (Non high-mileage flavor/formula) Once in a while I use Castrol or Valvoline.
    Canadian Caber and b_r_o[QUOTED] like this.
  11. Jun 27, 2025 at 11:16 AM
    #71
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The timing cover oil leak is kinda blown out of proportion on this site. Yes its expensive to fix but people don't understand how common timing cover leaks are - across all manufacturers.. not just toyota. Subaru is terrible, vw/audi is terrible. Honda are always seeping when they come in..
    For the most part toyota has some of the best gasket/sealing systems on the road. The 4.0 is not a leaker, the 4 cylinders aren't either..
  12. Jun 27, 2025 at 12:51 PM
    #72
    OnHartung'sRoad
    So would painting them fluorescent yellow with latex paint! Well… maybe just to another subject…o_O
  13. Jun 27, 2025 at 2:23 PM
    #73
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Pink will keep them from getting stolen.
  14. Jun 27, 2025 at 2:23 PM
    #74
    OnHartung'sRoad
    Not around here…
  15. Aug 25, 2025 at 11:57 AM
    #75
    casadetrevino
    casadetrevino New Member
    JT
    2021 Tacoma TRD Off-Road White
    2021 TRD, 39,000 miles - Just took it in for oil change and the PS boots have seepage. I'll be trying the Mazda fluid. Thanks for the tip and info on this thread!
    tonered likes this.
  16. Aug 25, 2025 at 12:18 PM
    #76
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Please post up if you see success with it.
    :cheers:
