Steering rack replacement, advice?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tree taco, Jan 15, 2013.
  1. Jan 15, 2013 at 2:41 PM
    tree taco
    tree taco [OP] New Member
    Flagstaff, AZ
    Flip-Pac, OME Dakar leafs, OME rear shocks, Ride-Rite, OME coils with Bilsteins in front, ARB Front Bumper, CBI rear bumper, custom pathfinder modded swing out tire carrier
    Hello all,
    I've been a long time looker on this forum, and this is my first post. My truck has about 109,500 miles on it (it has had quite a life already), so that means its time for new bushings on the steering rack. I know energy suspension will not come through with replacement bushings before I go mad from the unresponsive steering.
    My question to the forum is: Has anybody replaced the rack with a refurbished unit? My local shop quoted me almost $1100 for parts and labor to replace the rack and it is my understanding that the dealership is the same or more. I know that I can get a refurbished unit at about $75.00 net cost (with core). I am just concerned about the quality of the refurbished units.
    Also, do you think that me purchasing the part and paying for labor only would be more cost efficient?
    Thanks!
  2. Jan 15, 2013 at 4:33 PM
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    I've used a lot of rebuilt parts with very few problems. A quality rebuild part has all the wear and or damaged parts replaced and come with a good warranty.
    Depending on the shop labor rates might be higher for brought in parts and if you get the wrong part, don't get additional hardware or parts needed to correctly install the item, it is defective, your not going to be happy with the outcome. Most shops will warrant parts and labor for a period of time.
    I would do a little research on area repair shops and get some prices to compare.
    Jim
  3. Jan 16, 2013 at 12:34 AM
    brokeincollege
    brokeincollege 1<3
    bay area
    11 4x4 DC/LB TRD Sport
    When I had to replace the rack and pinion on my civic, it costed around $700 with a rebuilt one. I believe every repair/replacement use rebuilt ones as a brand new one cost way too much. I had no problem with mine.
  4. Jan 16, 2013 at 2:36 PM
    nilster
    nilster Member
    Nils
    Denver
    4X4 Trd
    Toytec Ultimate
  5. Jan 16, 2013 at 2:52 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    If you have go to an autozone or local parts store they sell refurbished ones for 80-120 bucks with warranty and install it your self or get couple buddies to help yeah out. 1000 bucks little steep
  6. Jan 29, 2013 at 1:50 PM
    BUB_IROC_Z
    BUB_IROC_Z Well-Known Member
    Anthony
    North Eastern Ohio
    2010 4x4 4.0 Taco
    3 inch OME, Rear diff breather mod, Aeroforce Interceptor Gauge and custom gauge pod, Yellow Wire Mod, Avid Off-road bar, Bud built Skid Plates,
    I think mine is starting to go as well. I cant find a leak yet but I did have to add some fluid and I noticed that it was whining a little taking normal turns.
  7. Mar 30, 2013 at 9:38 AM
    wobble
    wobble Well-Known Member
    Ridgefield, WA
    2014 TRD OR
    Modified RCD Lift, 315/70R17 STT Pros
    I know this thread is a few months old, but Moog makes replacement bushings for the steering rack. Perhaps this will help someone in the future.
    FirstGen Jer likes this.
