Steering rack source
Discussion in '1st Gen. Tacomas (1995-2004)' started by shift96, Jun 1, 2010.
  1. Jun 1, 2010 at 6:01 PM
    shift96
    shift96 [OP] Well-Known Member
    So I think I'm going to put a new rack in my truck. The one in it isn't that bad but I really want to tighten up the steering. Anyone know of a good source for a quality Repop? The dealer wants about $800 for a Toyota one. I know there are local places by me that offer them with warranties
  2. Jun 1, 2010 at 6:36 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    how about doing the steering rack bushings instead?? especially if the gears dong grind and grab......bushings are alot cheaper and not hard to install. just a thought.
  3. Jun 1, 2010 at 6:59 PM
    shift96
    Did them already and they didn't do a damn thing:confused: Aside from knowing I did them, I didn;t feel ANY difference
  4. Jun 1, 2010 at 7:04 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    damn!!
    well....check rockauto.com....their prices on stuff is alot cheaper than most other places...and they are a vendor here,so you'll get a discount.
  5. Jun 1, 2010 at 8:06 PM
    Mr.Fahrenheit
    Mr.Fahrenheit Dennis = sinneD
    American Canyon, California
    01 Taco 3.4L 5spd TRD
    K&N CAI, HUSKY LINERS, LOW PRO TOOL BOX, GRAY WIRE MOD, OPTIMA RED TOP, GOODRIDGE STEEL BRAKE LINES, FAB TECH LIFT,
  6. Jun 1, 2010 at 8:07 PM
    shift96
    Thanks for the tips guy's!
  7. Jun 1, 2010 at 8:07 PM
    Mr.Fahrenheit
    also i've notice that both our tacomas have play in the steering column not the rack....
  8. Jun 1, 2010 at 8:09 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah....the steering column slop is annoying. im gonna look into tack welding it a bit in a few weeks when i get time.
  9. Jun 1, 2010 at 8:15 PM
    shift96
    Could you tell me exactly what to tack weld? I have a welder. You guy's are correct in saying the play is in the column. I think it is the upper shaft and not the lower one down by the firewall. Only bummer is it's about $200 for that upper shaft. Would be real curious if tack welding it would work
  10. Jun 1, 2010 at 8:20 PM
    shift96
    I think this is the culprit
  11. Jun 2, 2010 at 3:18 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i am going to look into it some more and see what i find. this guy doesnt come here too much anymore since he sold his truck...but search threads by "srfive"
    http://www.tacomaworld.com/forum/members/srfive.html
    he did a small write up on tackwelding the problem area.
  12. Jun 2, 2010 at 3:34 PM
    shift96
    I searched all his posts and couldn't find anything on the subject. Darn:mad:
  13. Jun 2, 2010 at 3:36 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah.....so did i. im not sure if it was deleted or not. im gonna look into it...cause it was pretty helpful.
  14. Jun 2, 2010 at 3:57 PM
    shift96
    Yeah me too. Let's find it. I'm welder ready:D
  15. Jun 2, 2010 at 5:25 PM
    shift96
    I found this
    Anyone know how to get this shaft out?
  16. Jun 2, 2010 at 6:34 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    not sure...but there may be a roll pin in there.
  17. Jun 2, 2010 at 7:58 PM
    shift96
    Anyone know if it can be tack welded in place without taking the shaft out?
  18. Jun 2, 2010 at 9:31 PM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    Are you shitting me? Another factor that contributes to sloppy handling? I was hoping new suspension and rack bushings would sort my truck out. I guess I will just have to see after I install it and keep my fingers crossed that I don't have this issue, too.
  19. Jun 2, 2010 at 9:49 PM
    shift96
    I shit you not
    Also don't expect too much from the rack bushings. I put them in and I felt zero difference.
  20. Jun 3, 2010 at 5:29 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    new rack bushings will do nothing to cure the knocking noises or sloppy feeling you have in your steering system. ...it may make a difference if the old bushings were extrememly worn. ..but most of the movement i've seen from the racks are minimal. i also think most people change them out because they just don't like to see the damn thing move. ..not because it acutally cures any steering problems.
    i spent some time under my sled yesterday and found at least part of the problem. i just grabbed the steering shaft at the point where it goes into the actual rack. i then rotated the shaft back and forth with my hands and could hear/feel the "clunk" coming from inside the rack right at the point where the steering input shaft enters.
    i'd be curious to know if everyone's does the same thing. ...give it a try and post up!
