Steering rack still has movement
Discussion in '1st Gen. Tacomas (1995-2004)' started by 757yotas, Feb 10, 2017.
  1. Feb 12, 2017 at 1:25 PM
    #41
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    That clamp isn't bent at all, right? Looks true to form?
  2. Feb 12, 2017 at 1:40 PM
    #42
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    Long shot here: It's the correct rack, right? Looks right in your vid. Don't know if there is a printed part number on there. There's a foot of snow here or I'd check mine.
    Was it always this way, or did it loosen up over time? I've done a few of these, but never saw anything like this. Seems I remember someone some time ago saying the metal inside the bushing was too long on a run of replacement bushing sets which was leading to loose racks. I'd be tempted to get another set of energy suspension bushings and try again.
  3. Feb 12, 2017 at 2:03 PM
    #43
    757yotas
    757yotas [OP] Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Yes i replaced both outer tie rods since they needed to be done pretty bad. The suspension bushings i got are Energy Suspension #8.10103R.
    http://www.4wheelparts.com/Suspensi...ZuwRGZ5T_KZf0IeEyhqyvkKZky6PXzOv7XxoCuT7w_wcB
  4. Feb 12, 2017 at 5:14 PM
    #44
    wamego
    wamego Well-Known Member
    2002 Tacoma 2x4 TRD SR5
    You didn't have any extra parts when you were done???
  5. Feb 12, 2017 at 5:23 PM
    #45
    757yotas
    Virginia
    2007 TRD Sport
    Nope
  6. Feb 12, 2017 at 5:33 PM
    #46
    wamego
    Ok :). Kind of sounds like you did have the correct parts. It really shouldn't be moving. Maybe that is not the original rack.
  7. Feb 12, 2017 at 6:51 PM
    #47
    757yotas
    Virginia
    2007 TRD Sport
    Maybe not? Not sure why or how it would be though?? I hate problems like this haha
    FirstTimeFirstGen likes this.
  8. Feb 12, 2017 at 7:10 PM
    #48
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    in the video, that bolt thats just under the steering shaft u-joint/coupler, can you remove that bolt and take a pic of what's inside that bushing/housing?
  9. Feb 12, 2017 at 7:33 PM
    #49
    757yotas
    Virginia
    2007 TRD Sport
    The horizontal bolt and nut or the virtical bolt on top of the rack?
  10. Feb 12, 2017 at 9:44 PM
    #50
    CodeSeven
    Serge.
    Coachella Valley
    how about this. Do you feel that you did everything the way they explain it in the following video? Did you need to insert the bushings using a hammer/mallet? Did you use the correct bushings?
    Just like everyone has been mentioning, if you did the procedure like they are doing so in the video, you should not be having this issue at all whatsoever.
    Roadeater likes this.
  11. Feb 13, 2017 at 8:01 AM
    #51
    757yotas
    Virginia
    2007 TRD Sport
    Yes, but i used a style of C clamp to press the new bushings in due to limited space. I am 110% confident that the install was done properly. I think im just going to deal with the slight amount of movement. It is going to the dealership this week to have a front end alignment done so ill ask them to check over all my work one more time and see if they can find anything that i keep missing.
  12. Feb 13, 2017 at 7:20 PM
    #52
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    So I just did my energy suspension bushings today. I don't have much (if any) lateral (side to side) play. I have a little bit of forward and backward play (in that C bracket). Stopped by 4WP and asked one of their techs to look at it. He said minor play is normal, if not, the rack would break from excessive rigidity.
    And I'm not sure if it has anything to do with my model year being a 2004 but my stud and nut (for the C bracket) were on top, not on bottom like the video showed earlier in this thread. A local Toyota dealer did replace my rack about a year ago, so maybe the Tech did it. I don't think it matters as long as the long side of the C bracket is paired with the bolt. I made sure I put the longer side of the C bracket with the bolt (if you use the short side, the bolt wont bottom out because the threads aren't long enough). Torqued everything to spec. Despite the fact I still have a little play, the steering feels much better and I don't wander anymore.
    757yotas[OP] likes this.
