Steering rack troubles
Discussion in '1st Gen. Tacomas (1995-2004)' started by drizl16, Aug 19, 2013.
  1. Aug 19, 2013 at 11:04 AM
    drizl16
    drizl16 [OP] Well-Known Member
    Derek
    york, PA
    04 xtra cab
    exhaust, k&n intake, painted stock rims, TRD
    out of nowhere, starting having a nasty squeek when i turn to the right, not the left. I got under the truck and put my ear right next to the steering rack and thats def where the noise is coming from. was wondering if anybody else had this problem and might have a solution. Hoping to god the entire steering rack does not need replaced......
  2. Aug 19, 2013 at 11:24 AM
    SDSam
    SDSam from Dirt bike to Dezert Couch
    San Diego
    00 Tacoma prerunner
    Icon Shocks, BTF front, Deaver f67, 33's on stocks, Fiberwerxs 1pc, TDR S/C, Bed & Eng Caged
    If its not the inner or outer tie rods than its the rack and its not that hard to change out and yeah the entire rack. Fluid full?
  3. Aug 19, 2013 at 11:42 AM
    drizl16
    Derek
    york, PA
    04 xtra cab
    :(. power steering fluid is full
  4. Aug 19, 2013 at 11:48 AM
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    I did three on my old 95.5 over the years. Unfortunately rebuilding them was not really a viable option for me at the time, it was my DD and I needed it rolling.
    It sounds like there may be a small leak within the rack itself. Have you drained out the old fluid and put in some new stuff? The viscosity could be junk after *10 years of only being topped off. If that doesn't help and you have the time you may want to pull it out, rip it apart, and replace all of the seals/o-rings/gaskets.
    http://www.customtacos.com/forum/showthread.php?t=113620
    http://www.jcwhitney.com/1998-2004-...-rack-seal-kit/p3052420d2193y1998-2004j1.jcwx
    Replacing it isn't the end of the world, just a minor pain in the @ss. Plenty of info here on TW to step you through it. All said after alignment about $400 out of pocket.
  5. Aug 19, 2013 at 11:53 AM
    drizl16
    Derek
    york, PA
    04 xtra cab
    ill give that a try. just to let you all know it did happen about a month after I put my lift on....
  6. Aug 19, 2013 at 11:55 AM
    YOTA LOVER
    NH
    I was running 33's at 285... Just tearing apart the rack :D
