Steering rack...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by luka, Feb 25, 2013.
  1. Feb 25, 2013 at 8:06 PM
    luka
    luka [OP] Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    Better to just replace the whole rack or replace the seals with oem?
    My boot is leaking on the passenger side all over my LCA :(
    I never touched one so i'm not sure which option would be the "better" one.
    oem seals are about 100 , o'reillys are maybe 50ish
    750ish for the rack oem and 400ish for a cardone(o'reillys).
    I guess the other note, is there any physical difference between the 2wd & 4wd labeling? Like max turning radius or slightly different dimensions?
    thanks.
  2. Feb 25, 2013 at 8:12 PM
    EDJY
    EDJY Well-Known Member
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    Whatever you do I would go with oem.
  3. Feb 25, 2013 at 8:15 PM
    00PreRunner
    00PreRunner Well-Known Member
    Jackson, MS
    '05 DCSB 4x4
    2005 DCSB, 4x4, Auto. more to come...
    When my boot started leaking it wasn't long till the rack gave up. It got dirt, mud, etc. in the rack and killed it. May want to make sure that hasn't happened.
  4. Feb 25, 2013 at 8:18 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Whatever you do, DONT BUY A REBUILT STEERING RACK. I went through HELL a year ago with rebuilds. Bought a dealership one, no problems since. I have a first gen, but it's the same deal.
  5. Feb 25, 2013 at 9:23 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    FACT! Rebuilds are junk 99% of the time
  6. Feb 25, 2013 at 9:26 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    2WD usually means 5-lugger.
  7. Feb 25, 2013 at 11:17 PM
    luka
    Kailua, HI
  8. Feb 27, 2013 at 9:27 AM
    00PreRunner
    Jackson, MS
    '05 DCSB 4x4
    I don't have much experience with rack and pinion steering. It looks like it may be just as easy to replace the whole rack but like I said I don't have much experience with the rack and pinion set up.
  9. Mar 26, 2013 at 10:25 PM
    jhuey8947
    jhuey8947 Well-Known Member
    Tucson
    Lifted 02 Doublecab
    9" Fabtech lift, Custom paint, Leather Interior, Custom sound w/3 TVs, 20" Jesse James wheels, 35" Nitto MGrapplers
    Did you end up replacing the Rack & Pinion? What kind of time or special tools should I expect to need? Any help would be sweet.
  10. Mar 27, 2013 at 9:27 AM
    luka
    Kailua, HI
    not yet, haven't had time. I'll probably order an OEM rack and change it out myself..
