Steering sensitivity
Discussion in '3rd Gen. Tacomas (2016-2023)' started by noah_sobel, May 21, 2025.
  1. May 21, 2025 at 9:50 AM
    noah_sobel
    noah_sobel [OP] Member
    Noah
    Army Green 2020 Toyota Tacoma TRD Pro
    I have a 2020 TRD pro with 113000 miles on it. I live in San Francisco with very bumpy and uneven roads (lots of pot holes) my steering wheel turns and moves every time I go over a bump or pot hole. Driving on flat roads is fine even at high speeds. But just letting it roll and going over uneven surfaces the wheel will turn or move in response to these bumps. Any ideas on what this could be and how to fix it? I have a video but I can’t add it
  2. May 21, 2025 at 9:54 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Its known as bump steer. Slowdown and avoid the pot holes, your frontend alignment will thank you.
    t0p_d0g likes this.
  3. May 21, 2025 at 10:16 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Have you had an alignment in the last 100,000 miles? If not, I would get one and ask for a little more caster than spec. Much less bump steer and a little more control in the steering wheel.
    t0p_d0g likes this.
  4. May 21, 2025 at 10:19 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    have you modified the suspension?
    If so, did you get a proper alignment after the fact?
  5. May 21, 2025 at 10:55 AM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    Wide (or high-negative-offset) wheels will magnify that as well.
    noah_sobel[OP], Chew and airforceb2cc like this.
  6. May 21, 2025 at 12:41 PM
    noah_sobel
    Noah
    in sf you can’t avoid them and trust me just letting the car roll over them with no gas will make it happen lol
  7. May 21, 2025 at 12:42 PM
    noah_sobel
    Noah
    no that might be why the guy I bought it from said he did a bunch of service to it. Homie was full of it so I’m doing all the service now. I’ll def be getting an alignment what does more caster do?
  8. May 21, 2025 at 12:42 PM
    noah_sobel
    Noah
    No I have not
  9. May 21, 2025 at 12:47 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    I recommend as other members get an alignment and have all the steering components checked you may have some worn parts.
    Other than moving you may have to hold on tight and live with it.
  10. May 21, 2025 at 12:54 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Imagine the front wheels of a grocery cart. the more you offset them rearward from the steering pivot, the less they wobble. I agree with pushing the caster forward by a half degree or so. Also agree with having the front end bushings looked at.
    airforceb2cc and t0p_d0g like this.
  11. May 21, 2025 at 1:04 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    As mentioned, check suspension components, get an alignment. To add to that: I believe the service interval on the Fox shocks is 50k miles,,,, either way, way overdue, so that is a consideration too.
    t0p_d0g likes this.
  12. May 21, 2025 at 7:58 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Although I’m having trouble finding a good reference at the moment, I believe increased caster can actually increase bump steer. It’s best to simply adjust alignment to spec.
    In any case, a certain amount of bump steer is normal and unavoidable. It’s impossible for us to determine if yours is normal or abnormal without driving the truck ourselves.
    t0p_d0g likes this.
