Steering Shaft TSB?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jimsc, Sep 12, 2011.
  1. Sep 12, 2011 at 4:57 PM
    Jimsc
    Jimsc [OP] Well-Known Member
    Jim
    Greenville, SC
    10 PreRunner Double Cab
    Aries Nerf Bars, Cargo Seperator
    I had this done and it doesn't feel any better. It was never that bad really and you only noticed it on gravel roads, but I wonder if they really replaced it at all? Is there anyway to tell? Does the replacement look different from stock?
  2. Jan 6, 2012 at 9:18 AM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    I'm curious about this too. Had the steering tsb done, even cross referenced the new part to the tsb document to ensure they got the 'new' part and not just replaced the old one with another stock one.
    As Jim mentioned, it wasn't that bad before, but I can still feel a looseness when going over speed bumps slowly.
  3. Jan 6, 2012 at 9:54 AM
    xxaarraa
    xxaarraa Well-Known Member
    Yes, TSB had no effect on me either. In fact, it now feels worse. There is a thread on a zip tie fix and seems to have worked for many folks:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/88077-steering-column-fix.html
    Unfortunately, those of us that got the TSB can't do it because the new bushing they put in the shaft doesn't have enough room to get a zip tie in there. My biggest gripe with this truck is this steering rattle.
  4. Jan 6, 2012 at 12:05 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Interesting , getting the TSB done made my steering way better , no more slop .
  5. Jan 6, 2012 at 12:07 PM
    jivewalker
    jivewalker Well-Known Member
    Jack MeHoff
    Chucktown
    2012 4RUNNER TE w/KDSS, 2017 LAND CRUISER
    Had the TSB and no improvement. Drive on gravel daily and is very noticeable. At this point I'm accepting it as the nature of the beast.
  6. Jan 6, 2012 at 3:21 PM
    xxaarraa
    Wonder if it's something else entirely and not the intermediate shaft. Some folks with the TSB say things are better, but many say things are the same or worse.
    I have heard the tilt column u joint can cause issues, but I played with mine and greased it and doesn't seem to be the case. I'm out of ideas. Sigh.
  7. Jan 9, 2012 at 2:16 PM
    kram
    kram Well-Known Member
    Squamish, British Columbia
    09 TRD Offroad Access Cab 6spd MGM
    URD Short Shifter TSB Leaf Pack, Bilstein 5100s front (1.75") and rear. 285/70/17 Duratrac on Rhino Sidewinders. Weathertech Digifit Floormats
    Mine is way worse. Drives me nuts. I can hear it knocking, and so can my passengers under the right conditions. The dealer says it's my inner tie rod ends that may need replacing, but can't tell me that it will actually fix it. Any know if this sounds like bull, or is worth considering? I've got 40K on my truck.
  8. Feb 27, 2012 at 3:44 PM
    deeznutz
    deeznutz Well-Known Member
    Seattle, WA
    09 SR5 DC LB 4x4
    Any updates on this? I was about to contact the dealer and schedule to get this done but now I'm on the fence after reading some of the threads.
  9. Feb 27, 2012 at 6:29 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    I have used a o-ring packed into the bushing and it did the trick for me.
  10. Feb 9, 2016 at 1:17 PM
    JUJtacoma2010
    JUJtacoma2010 Well-Known Member
    Fresno
    Tacoma 2010 Dbl Cab. OFF Road Package
    anyone has link for the updated tsb pdf?
