Steering shaft zip tie fix issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SamuelJ, Oct 17, 2018.
  1. Oct 17, 2018 at 10:00 AM
    SamuelJ
    SamuelJ [OP] Darkhorse
    Samuel
    33.9269893 -118.0185768
    2012 DCLB 4x4 Trd Sport
    Shortened flowmaster exhaust with a turn down pipe, under cowl intake, throttle body spacer, train horn, underhood led lights, hood struts, dual 27f yellow tops. Led ditch lights, led front roof light bar, led fogs and headlights, behind grill mounted piaa dual color driving lights. Aux fuse and relay panel. Pro comp skid plate, bilstein 5100 leveling shocks on a 2in. lift, b110 rear 5100, add a leaf, front superbumps, light racing jounce rear bumpstops, sway bar relocation, brake line bracket extension, driveline carrier bearing drop, front diff drop, on board air compressor, 10 gal pump driven fresh water tank, cb radio, pioneer 4200 hu, infinity reference component front and component rear speakers powered by rockford fosgate 4 channel, jl audio 10TW3-D4 sub powered by kx800.1 amplifier. Big three upgrade, capacitor. Full cab sound deadening and thermal insulation. Led interior including added footwell, courtesy, cupholder, center console, and glovebox lighting, rock lights, bed lights, ring gear armor, under bed ammo can storage, pistol safe, body armor sliders, roof rack, hilift, 285/70 17 nitto rodge grapplers on american racing teflon atx, tailgate strut, and tailgate lock, retrofit projector headlights(home built), rgb halos inside turbine shrouds, black out surround, black chrome reflector and shroud, white halo outside shroud, white led drl, rgb behind grill on rf control. Mods followed from a TW thread: Anytime fogs Anytime rear view camera Anytime 400w inverter Alternating blinker/running lights 110v center console outlet ABS kill switch Engine kill switch (magnetic) 12volt bed socket Rear diff breather relocation Led bed lights Cargo net anchors Grid it center console top Grid it sun visor Locking center console Instrument cluster led swap Map lights on with dome Cigarette lighter add (shifter position) Dtrl kill switch Hilux lighted 4wd selector switch. Vios hvac knobs Hood scoop led bar
    I should have left it alone, but I didn't. I had the steering wheel loose feeling in my taco and read about the zip tie idea. So giving it a shot I cramned a zip tie in the collar at the bottom where the others have done. It did feel tighter but there was an annoying clicking noise when I would turn the wheel. Thinking maybe I was 90° off I removed it and put one on the side. Same click, so removed and reinserted another 90°(now 180°). Same click, another 90, same click. Damn it! So pulled it out and now with no ties at all its clicking. Wtf? Anybody have an idea what I should do? And yes I know, should've left it alone.
  2. Oct 17, 2018 at 11:21 AM
    Taco'09
    Taco'09 Well-Known Member
    Put in the TSB intermediate shaft.
    blu92in99 likes this.
  3. Oct 17, 2018 at 3:39 PM
    jkulysses
    jkulysses Well-Known Member
    Jake
    Oregon
    01' Tacoma 4x4 3.4l 5 spd
    What is the steering shaft issue exactly or where can I read about it? I'm having a weird issue when I drive on gravel roads it feels very weird almost like something is loose or shifting in the steering column somewhere. I've never felt anything like it before.
  4. Oct 17, 2018 at 4:57 PM
    Taco'09
    ..........and it may likely clunk as well.
    The issue is the bushing in the center of the upper steering intermediate shaft becomes worn and deformed and lose. This contributes to sloppy steering and noise. There is a redesigned (upper) intermediate shaft to address this.
    The other issue that seems to be raising its head more and more as the 2nd gens age is the rusting of the needle bearings in the lower intermediate shaft causing hard steering and even some accounts of the sudden steering loss. This seems to be more frequent in the rust belt and areas where the lower shaft encounters water a lot.
    Honestly, if this were mine truck and I planned on keeping it for some time I would just replace both.
  5. Oct 17, 2018 at 5:02 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
  6. Oct 18, 2018 at 12:25 PM
    SamuelJ
    Samuel
    So do you think its the upper or lower intermediate? I looked at the tsb and dont see an issue changing it myself but dont want to replace the wrong one. Thanks for the info btw, much appreciated.
  7. Oct 18, 2018 at 7:45 PM
    Taco'09
    The upper is generally where most of the looseness and noise occurs.
    The bottom one does just the opposite if the ujoint rusts. It gets stiff, or could seize.
    Age, mileage and exposure are considerations and you may not need the lower on a '12 yet unless you are where the ujoint on the lower shaft gets hit with water/slush a lot.
    If the lower looks marginal I suggested doing both primarily because both shafts are poorly designed and constructed. The looseness and clunk in the upper is annoying for sure but not a safety issue. The lower has the potential to be a serious issue (loss of control).
    b_r_o likes this.
  8. Oct 18, 2018 at 9:13 PM
    SamuelJ
    Samuel
    Interesting and useful information, thank you. As it sits the lower is in excellent condition. The boot looks great, no rust, and as far as I can tell it doesn't present a safety hazard. Upon closer inspection the upper is what makes the noise(like you said). It had a thin plastic ring which had come dislodged and was sitting crooked which allowed the end of the lower to come into contact with the joint creating the click. I managed to straighten it on the shaft and I happened to have a rubber end cap off of a form roller for my press at work. They come that way from the manufacturer to protect the journal during transport. It fit perfectly on the end of the shaft and added another layer of protection against allowing the two to come into contact. So far, so good. It even feels like it tightened up the joint which is what I wanted in the first place. Took a quick run thru the canyon close to my house after work and feels great and no freakin noise. I am slightly concerned about if this could cause any safety issue. I dont think so however I am not an expert, obviously. What do you think?
  9. Oct 19, 2018 at 12:36 PM
    Taco'09
    Got a pic? I've taken the guts out of about three of those shafts and tried all kinds of DIY bushings inside. Would like to see what you did.
  10. Jan 12, 2021 at 5:29 AM
    BigHoss96
    BigHoss96 Well-Known Member
    Matthew
    Boston MA
    2014 DCSB trd sport
    315/75/16 Geolandars on FZJ80 wheels Elka 2.5s RR Coilovers JBA UCA's Moog LCA's All-pro rock sliders All-Pro leaf pack w/ U-bolt flip kit ARB front bumper Badlands 12K winch Spyder Projector headlights\ BD fog lights Cowl air intake relocation
