steering shaking after adding 3" lift
Discussion in 'Suspension' started by tstreet, Sep 18, 2009.
  1. Sep 18, 2009 at 2:12 PM
    tstreet
    tstreet [OP] Member
    Troy
    VA
    2008 tocoma 4x4
    3" lift kit
    After adding a 3' sup. lift kit to my 2008 tomoca, Im having alot of steering shaking at speeds between 40-55 mph. Wheels have been rebalanced, new BF Goodrich all terrian tires. 33x11.5. still shakes. Anyone know a fix for this ?
  2. Sep 18, 2009 at 2:13 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    What kit do you have?
  3. Sep 18, 2009 at 2:20 PM
    azTRD
    azTRD Well-Known Member
    You mentioned the wheels being balanced... but did you have an alignment done after your lift?
  4. Sep 18, 2009 at 2:25 PM
    azTRD
    A number of trucks will get drive line vibrations after lifting their trucks... are you sure it's coming from the front end (steering) or could it be coming from the drive line? I'm just trying to narrow down what the possible cause might be.
  5. Sep 18, 2009 at 2:29 PM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    ]After adding a 3' sup. lift kit to my 2008 TACOMA, <---fixed it for you, unless it is a one of a kind....then I apologize.
  6. Sep 18, 2009 at 2:33 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Rotate your tires....put the front tires in the rear and rear tires in the front.
    Drive it and see what happens.
    If the steering wheel doesn't shake, then you have a problem with one or both of the wheels/tires that are currently installed in the rear.
    Let us know what you find out.
  7. Sep 18, 2009 at 8:41 PM
    Tsenekos
    Tsenekos Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    mine seems to do that too after I did a 3" lift arounf those speeds too its not really bad but it wiggles back and forth I rechecked my tire psi etc still has it
  8. Sep 20, 2009 at 9:28 PM
    dabighi
    dabighi Well-Known Member
    not exactly sure what kit you have on there..but did you replace the uca's?? it may be that your alignment is off and you just seem to notice the "shaking" more at those speeds.
  9. Sep 21, 2009 at 12:04 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Have your drive shaft checked and balanced.
  10. Sep 21, 2009 at 1:09 PM
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    If you still have your stock tires and rims, put them back on and take it for a spin. If it still shakes, then you have eliminated your new tires as the problem.
  11. Sep 21, 2009 at 1:19 PM
    Padilla1880
    Padilla1880 "Let's Ride!"
    Daniel
    Temecula, CA
    05 TRD OffRoad V6 SR5 PreRunner
    Did you have an alignment after your lift install? Get your wheels Road Force Balanced. Just enter your location and it will find the closets Road Force Balancer near you.
  12. Sep 21, 2009 at 6:12 PM
    tstreet
    tstreet [OP] Member
    Troy
    VA
    2008 tocoma 4x4
    3" lift kit
    Forgot to mention that i also had the front end re aligned after ballancing. tires were switched from front to back. It made it a little better ,but not much.
  13. Sep 21, 2009 at 6:15 PM
    tstreet
    tstreet [OP] Member
    Troy
    VA
    2008 tocoma 4x4
    3" lift kit
    Had alignment done also, everything checked out fine.
  14. Sep 21, 2009 at 6:21 PM
    tstreet
    tstreet [OP] Member
    Troy
    VA
    2008 tocoma 4x4
    3" lift kit
    Not sure where its coming from! Switched front to back tires, made slight differance, but not much. Is it possible these guys sold me a bad tire? Reaction from truck seems to change as the weather changes.
  15. Sep 21, 2009 at 6:26 PM
    tstreet
    tstreet [OP] Member
    Troy
    VA
    2008 tocoma 4x4
    3" lift kit
    toyota ready lift installed 3" 600 dollor lift. All the rest is factory .
  16. Sep 21, 2009 at 6:28 PM
    tstreet
    tstreet [OP] Member
    Troy
    VA
    2008 tocoma 4x4
    3" lift kit
    Same here brother.
  17. Sep 21, 2009 at 6:33 PM
    tstreet
    tstreet [OP] Member
    Troy
    VA
    2008 tocoma 4x4
    3" lift kit
    Did not replace the uca's . Replaced with 3" ready lift . They said that was all I NEEDED.Maby I got taken for a ride!
  18. Sep 21, 2009 at 6:34 PM
    tstreet
    tstreet [OP] Member
    Troy
    VA
    2008 tocoma 4x4
    3" lift kit
    Good idea I'll try this.
  19. Sep 21, 2009 at 9:54 PM
    cgilbane
    cgilbane Well-Known Member
    Avon, CO
    07 Tacoma dbl cab
    remote reservoir fox shocks front and rear
    what came in this Toyota ready kit?
  20. Sep 21, 2009 at 9:56 PM
    cgilbane
    Avon, CO
    07 Tacoma dbl cab
