steering squeal
Discussion in '1st Gen. Tacomas (1995-2004)' started by wheeler3129, Feb 27, 2012.
  1. Feb 27, 2012 at 11:06 AM
    wheeler3129
    wheeler3129 [OP] Well-Known Member
    Lexington, NC
    2003 Tacoma SR5 4x4
    while inspecting ball joints, cv joints, and tie rods for a popping noise when I turn the steering wheel all the way to the left or the right it sounds like a belt squealing. I have never heard this before and just want to fix because it is annoying.
  2. Feb 27, 2012 at 2:13 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    If its the belt , check it for tension & wear
  3. Feb 27, 2012 at 2:26 PM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Currently under the knife for turbocharger..
    When your PS system is at full lock there is a very high load on the pump, this is when its most prone to squeal by slipping. Check for cracks in the belt, if there are none just tighten the belt and your good to go, if there are cracks replace the belt, if thats the case might as well get all new belts (3 total if you have AC)
  4. Feb 28, 2012 at 7:01 AM
    wheeler3129
    Lexington, NC
    2003 Tacoma SR5 4x4
    Is it tough to change the belt or tighten if needed, can I do it?
  5. Feb 28, 2012 at 7:13 AM
    Texasdynaryder
    Texasdynaryder Well-Known Member
    Chance
    Paris, Tx
    Kings Built Engine All the other small goodies
    All you will needs is a small socket set and a couple wrenches. Drop your skid, then loosen off all the belts and slip new ones back on. Simple fix and only takes 30 minutes or so. Good luck
