steering stabilizer?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco95, Aug 2, 2007.
  1. Aug 2, 2007 at 7:58 AM
    Taco95
    Taco95 [OP] Active Member
    i have a 95 tacoma 4wd, it's had alot of bumpsteer since i've owned it (mostly i think because of the 31's on it) but i've looked and looked and it seems no one makes an aftermarket steering stabilizer for a 95?
    anyone here had any luck? or will something from like a 4 runner possibly fit it? i need something done, it shouldn't shake this bad at 65mph + i mean once your up around 85 you've really gotta hold on and watch yourself because if you let go it'l go just about everywhere from the slightest bump in the road.
  2. Aug 2, 2007 at 8:40 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    What kind of lift do you have on it? You have to remember you're driving a truck and not a car going 85 and you're bound to have some vibrations.
  3. Aug 2, 2007 at 12:09 PM
    Taco95
    no lift, just 31 10.5 15 BFG all terrains.
    I wasn't informed of a lift if it has one, and im positive it doesnt, but the way this thing shakes at 65 is how it should feel at 85, i can let my fingers hang on the top of the steering wheel and you can see your fingers shaking something fierce.
    im going to try other areas to fix the problem - shocks/ball joints/ tie rod ends/ i just had the tires balanced - no difference.
    just a toyota tacoma 4wd, no lift not been wrecked its perfectly in align it doesn't wander the slightest bit - it just has bump steer something awful.
  4. Aug 2, 2007 at 12:49 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    I have the exact same problem with the 99 taco Pre-runner 2WD.
    My late son just got it 3 months ago, and we traded each other about 4 weeks ago as he could never come up with any cash to fix what it needed.
    I had the timing belt , water pump and horn and seatbelt replaced at the Stealership. Tires rotated and balanced abd still wobbles like mad at 65.
    I just purchased these two items.....
    and
    Haven`t got both yet, as I`ll install them at the same time and see if that helps it out. If not...then on to ball joints and such
  5. Mar 17, 2008 at 11:49 AM
    awwheck
    awwheck New Member
    SR5
    Has the problem been solved? I'm having the same problem...Help please
  6. Mar 17, 2008 at 11:51 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    Those and a Lug-centric balancing made 95% go away.
