steering stablizer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bluebeast, Mar 26, 2010.
  1. Mar 26, 2010 at 7:30 PM
    bluebeast
    bluebeast [OP] Active Member
    06 bluebeast
    smitty bulls bar procomp 3in lift westin nerf bars
    i have an 06 tacoma. lifted about 3inches and got an aligment 3 weeks ago. just pick up my wheels and tires 3 days ago. 295-65-18 with wrangler duratracs all terrian and now my steering has quit a bit of shimmy in it. on the highway or city u can really feel the steering wheel moving. does this mean i need steering stabilzer shocks or does it mean i need to realign again. any suggestion or input would really help. thanks
  2. Mar 26, 2010 at 7:33 PM
    Sparky4.0
    Sparky4.0 Well-Known Member
    Aaron
    WestTexas
    01 trd beat to hell
    steering stabilizer shocks are a bandaid fix for an underlying problem. avoid them at all cost.
  3. Mar 26, 2010 at 7:35 PM
    PreRunner
    PreRunner Well-Known Member
    just lifted mine 3", and got new duratracs as well but mine are 265/75/16 (c). zero shimmy. id have them re-examine the balancing.
  4. Mar 26, 2010 at 7:36 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    First go out with a tire gauge and set you tires at 32PSI. Tire shops often seem to overinflate mine and it makes the steering all squirrely.
  5. Mar 26, 2010 at 7:38 PM
    Tillers_Rule
    Tillers_Rule ......................
    Jeff
    San Diego
    4x4 Sport, debadged
    Icon coil overs up front, Total Chaos UCA, Icon remote reservoir in the back with Deaver 11 pack leafs. Sunroof, Hella 500's behind grill.
    As well as cause other steering components to prematurely wear dues to the increased resistance.
  6. Mar 27, 2010 at 10:31 AM
    bluebeast
    06 bluebeast
    cool thanks guys
  7. Mar 27, 2010 at 10:32 AM
    bluebeast
    06 bluebeast
    is it that bad to use the steering stablizer
  8. Mar 27, 2010 at 10:35 AM
    Sparky4.0
    Aaron
    WestTexas
    01 trd beat to hell
    yes........ would you put your truck together with duct tape? it will work 4 a second but its not a proper fix
  9. Mar 27, 2010 at 10:41 AM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    If you are using it to hide a problem, yes, it's bad.
    If everything is kosher, a steering stabilizer is unnecessary on road but it can be a nice addition off road because it helps control bump steer.
  10. Mar 27, 2010 at 10:43 AM
    Sparky4.0
    Aaron
    WestTexas
    01 trd beat to hell
    the ifs gearbox dont have much bumpsteer feedback anyways.. ps you would have to have some good fab skill to mount a steering stabilizer on an ifs truck..
  11. Mar 27, 2010 at 10:48 AM
    Brunes
    Brunes abides.
    Rotorhead
    Fixed it for you- 32PSI is a guess. Chalk line test beats a specific PSI any day. Specially with aftermarket tires.
  12. Mar 27, 2010 at 10:49 AM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    Good point. I've never looked into steering stabilizers for a Tacoma because I've never felt I needed one. I was speaking generically I guess. I had one on my Bronco and it was nice off road. It had a IFS and a simple bolt on stabilizer. It was a pretty unique IFS though. I don't know if you've ever seen that weird scissor type IFS they had on those last generation Broncos. I think the Rangers had it too.
  13. Mar 27, 2010 at 10:53 AM
    Sparky4.0
    Aaron
    WestTexas
    01 trd beat to hell
    ttb twin traction beam dana 44 on the half tons... twin I beam dana 44hd on the 250. and mono beam dana 60 on the 350 which was'nt scissor type.
  14. Mar 27, 2010 at 10:53 AM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    Another thing, Discount Tire set my 285's at 45 psi!:eek: I'm running them in the low 30's right now. It was a noticeable difference at speed. I've been meaning to do the chalk test but haven't gotten around to it yet.
  15. Mar 27, 2010 at 11:00 AM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    Yep, you know it. Strange system it was. It was kinda cool in theory but like any system, it had its drawbacks. I had the Dana 44 too but I'm pretty sure it wasn't HD. When I lifted it and put on the extended length radius arms, I got to know it all too well. You had to be real careful where you mounted the radius arm brackets on the frame because each side of the axle could move a little forward or back independently. Obviously you wouldn't want one front tire farther forward than the other.
